Nightmares in the daytime.
Posted: January 10, 2016, 10:25 am
Some time back, I decided to tear down the 351w for my grandsons truck. Somewhere along the line I ran across and add for a 69 block and thought that would be a better choice for rebuilding. Very rusty but stock bore. Took it to the machine shop and had it bored cleaned and deck trued. Total came to a whopping 650 for the work. which I thought was very high. Got the block home and started installing cam bearings and cam. When done with that I decided to install the crank. This is when I ran into trouble. Crank went in fine but when I installed the number 3 center thrust bearing the crank locked in place. Thought maybe the crank was bent so installed a different crank with a little wear with the thought that the looser crank might help. No go. Noticed no end play on crank even when only slightly tightened center main bearing bolts. Took all the other main bearings off pulled the center on down and it locked the crank again . I had plastigaged the bearings when I installed the new bearings and had noticed the center being tight.
After loosening and tightening the center cap I notice it walked to the side and thrust bearing showed impression on bottom of one side and to of other. Got suspicious and took the cap off and put a square to it. Some jackass in the past had apparently done some shade tree grinding of the caps ends where it fit the block. It was about 1/32 off from one side to the other causing the bearing to kick to one side. Please bear in mind, I already have roughly 800$ in this block and now have a daytime nightmare. Because the Chinese were buying all our scrap at high prices, every scrap block in the country went to china which makes it nearly impossible to find a cap that will fit close enough to be align honed to fit. I have gotten two , one of which will fit fairly well if I turn it backwards. Otherwise it will have to be lined bored if there is to much that has to be removed, or I would go with four bolt caps. Not having any experience with installing 4 bolt caps, wondering if it is better to get straight four bolt caps or go with ones that have the outer bolts at an angle. I'm thinking at angle are best , but most likely will require being drilled in a machine shop. Some of the caps I've seen come with and drill sleeve but only on straight in bolts.
Since I've already spent a fortune on this block, I have decided to put it aside and bore a 74 block for my grandson, which I what I should have done to start with. I will think on what I will do with the 69 block. 4 bolt mains and a stroker kit may be in it's future, although I've heard there is a problem with stoking one of the early blocks. Anyone have insight on that?
