hood issues
Posted: February 16, 2016, 12:53 pm
by unibody madness
I did a search but was hoping for a basic approach to hood hinge alignment.
I realize that the passion and detail among the group exceeds the knowledge of most body shops. They could not not manage to align hinges and hood, after a great job of body work and paint for the price.
They sprung my driver side hinge that was in great shape, and wanted a basic how to on where to start before I ruin the replacement. Right now hood is off to the drivers side and although it clears when closing it scrapes when opening.
John
Re: hood issues
Posted: February 16, 2016, 5:41 pm
by Roger Carter
When I install a hood I try to set it as high and as far forward as possible, as a starting point. This usually eliminates the hood contacting the cowl. Once the hood opens and closes without contact I then set gaps by "creeping up" on the desired gap.
I also like to leave the latch off until the hood is where I want it. You don't want an improperly adjusted latch dictating where the hood rests.
It goes without saying that bent or sloppy hinges make this task near impossible.
I "fit" the hood to the cowl first, since the cowl is fixed. Then I proceed to fit the fenders and header to the hood. Quite often I have found it necessary to shim the core support to get decent fits for the fenders and header.
Remember, start any panel fit by fitting to the fixed piece and by starting big and working to close the caps.
A strip of masking tape along any potential contact points can save a lot of frustration.
A buddy, a pile of shims and tons of patience will make the job a bunch easier.
Hope this helps. Good luck.
Re: hood issues
Posted: February 17, 2016, 7:29 am
by bruceandersson
The biggest issue I've often seen with alignment is the height of the back of the hood. They tend to be higher than the cowl. You can fix this by using a wedge shaped shim with the larger end towards the front. This effectively lowers the pivot point when shut.
Re: hood issues
Posted: February 18, 2016, 10:46 am
thats what i did
brought the back down to meet the cowl
