Maching front disks to fit a smaller center hole.
Posted: March 31, 2016, 12:24 pm
by btalley63
Hello All,
I have a set of steel wheels that work fine on a truck with drum brakes.
When I put them on the truck with disk brakes, the center hole is too small.
Has anyone ever machined down the center hub on a front brake disk to fit in a smaller center hole?
What little I know about a brake lathe looks like it could be easily done.
I need to get some calipers out to see how much material would have to be removed.
Thanks for the info.
B.
- wheel.jpg (13.63 KiB) Viewed 2603 times
Re: Maching front disks to fit a smaller center hole.
Posted: March 31, 2016, 5:49 pm
by Toyz
Be aware that, depending on the wheels, caliper clearance may also be a factor.
Posted: April 1, 2016, 7:59 am
i would say it depends on how much meat is removed so that proper support for the outer bearing still exists.
Posted: April 9, 2016, 11:40 am
by Truckrat
Bill, if the center hole on the wheel is a little small
why not machine the center hole out to fit the hub instead.
But, if the wheel is not a disc brake wheel you will have
interference between the wheel and caliper. A disc brake
wheel has more clearance on the back side than a drum brake
wheel because of the clearance needed for the caliper.
Might be a better idea to find some disc brake wheels off
a later model truck or through the aftermarket if you want
to run the innie style caps. TR
Posted: April 15, 2016, 9:37 pm
by 62bigwindow
When I put front discs on my 56 Ranch Wagon I had to machine down the hub to clear stock wheels. As long as there is plenty of material I'd do it that way.
Posted: April 16, 2016, 2:36 pm
by Roger Carter
I machined the bearing snout on the front rotors to allow my wheels to clear. As I remember I took about 3/16" off the outside of the snout, back about 1 1/2". I did this almost 20 years ago and there hasn't been an issue.
I was using an original set of American Torque Thrust wheels, and machining them wasn't at option. The "hub hole" in the Americans was tapered, larger at the mounting surface, so a partial trim on the bearing snout was all that was needed. Clearance for the caliper wasn't an issue.
Good luck.
Posted: April 16, 2016, 7:42 pm
by Toyz
Just put 15 x 7 Torque Thrusts, (probablty TT II's), on my CS with the '77 suspension/brakes, no hub clearance issues. Wheels cleared the caliper until the stick-on balance weights were applied. They then rubbed. I was able to find some thinner width balance weights and put them as far inboard as possible. Problem gone, but it is extremely tight clearance.
