Door Hinge Pins
Posted: April 19, 2016, 6:15 pm
Are the pins in the door hinges supposed to rotate in the arm (that the door bolts to) or in the bracket (that bolts to the cab)?
I had an original set rebuilt by a local shop and noticed that some of the hinge pins rotate in the bracket and others in the arm. I'm not sure whether the shop rebuilt them wrong or if the pin is supposed to just rotate however it wants.
It seems that the pins should rotate in the arm since there is so much more meat there compared to the stamped bracket and won't wear out as quickly.
So does any know how they came from the factory?
