front end question on non ford car
Posted: September 28, 2007, 8:11 am
by willy3486
I have a question about my daily driver. I have a 98 sunfire that has 170k miles on it so I hope to not put too much in it. I have fairly new tires that were balanced that has never had a puncture. I have lifetime rotors and brakes that have very little wear. I had a brake line leak yesterday and noticed the cv joint boot was split. I checked the other side and it has split also. They were fairly clean and greased up. In other words somewhat lubricated and no dirt I could tale. The car makes a noise thats like vumpt-vumpt that sounds like it does it once with each revolution. It starts that at around 15 mph and starts getting quieter at around 30. I also have noticed that going around curves it does not make the noise. I put the new brake line on and put grease in the cv on the side I was working on. The noise was not that noticable today . I also checked the play on the shaft and it does not have up and down but it does have some in and out with the car jacked up and the tire off. I figure the in and out is due to the axle needing some to compensate for things like potholes. I have seen these split boots that replace the original boots. I really do not want to get into replacing the cv joints due to the age and mileage of the car. I was planning on buying a newer lower mileage car in the spring. So my question is from the description of the noise does it sould like the cv joints. The other part is If I clean and grease the joint then put a new boot on should I be able to get some more miles out of it. I am hoping to drive it at least until next spring or hopefully to 200 k . So do you think I can get a few more miles if I do the new boots on it?
Posted: September 28, 2007, 9:38 am
by shawns fords
I would say it is your CV joint, but it could also be the wheel brg itself, if you replace the boot and grease it up, im sure it could last you until next summer, if that is where the noise is coming from, if its your wheel bearing, then it might not last you that long, then sealed bearings wear out pretty quick, if you want, take wheel back off, turn the hub slowly by hand and feel for roughness. if it feels smooth then its not the bearing. when they first start making noise, you check them and have a hard time feeling them, after you get used to checking them all the time you get to know what to feel for.
Posted: September 28, 2007, 11:22 am
by Slick Fan
I bet it's a wheel bearing too.
Failing CV joints usually make a "clackety" sound, most easily heard with lots of throttle as you turn a corner.
The spilt CV boots sometimes work well, sometimes not. Just make sure to not get any grease into the seam before you seal 'er up...easier said than done.
Posted: September 29, 2007, 6:40 am
by fmartin_gila
Think that is close to the two Geo Metro's that I have. When the CV Jpints start to wear, you will get a clicking noise while accellerating in a corner. I replaced the whole axles(includes both CV Joints on each axle) in the 96. Cost was about $70.00 per side from Checker. The 94 is starting to have a slight rumble while making slight s turns while coasting, I suspect that the rumble is wheel bearings, so will have to check more on that.
I don't know about the replacement boots, since the axle sets come complete ready to slip in.
Fred
Posted: September 29, 2007, 10:06 am
by banjopicker66
Pin down first if it is bearings or axles. I don't know how GM does it, but most later cars and trucks have bolt-in bearing assemblies, and are easy to change.
Jack the front up, remove both front wheels, put it in gear, and listen for bearing noise with a mechanic's stethescope (or long screwdriver.)
If it isn't the bearings, then the better question is: How much longer do you want or expect it to last?
If a while, I would replace the entire axles, like gila says. The work to remove and replace the axles is the same needed to remove and replace them anyway to replace the boots.
Yes, I know they advertise that you can do it on the car - but I wouldn't. Take the time to do it right.
Just my thoughts, anyway.
Best of luck!
Posted: September 29, 2007, 10:13 am
by willy3486
Well I got one boot on today. They only had one. It wasn't the main noise but it sounds a little better. I even rotated the tires to see if that was it. I also checked for roughness in the bearing and it seemed fine. I put the front up and out of gear. The wheels turned fine and no looseness or roughness. One thing though I did get to talking to the parts guy yesterday. He said it might be the brake calpier is bad. I think thats what its called, the part the brake pads go into and it pushes them into the rotor. He said it would get to where it sticks or something. He said that would cause the pads and rotors to to wear out faster than normal. And that is what has happened a lot. I do not live in the city and do not ride the brakes. In fact I plan ahead so as not to use them as much as others do. But I have had trouble with them going out quickly. Another thing is that when you do apply brakes the noise I have been hearing stops and you start getting brake noise and shaking in the front. I have been having this noise for quite a while . I started noticing a faint noise about 15k miles back and thought it was just wear to the pads. But it got lounder and leveled out about 5-10 k miles ago. I am guessing the wheel bearing would not have lasted that long.The sound is really similar to brake pads going out. I was getting ready to change them but the rotor and pads look fine. So does this sound like it could be the calipers? As far as I can tell from checking and what has been replied here it does not seem to be a wheel bearing or cv joints. The rotors look good as well as the pads. So the only other thing I can think of is the calipers.
Posted: September 29, 2007, 10:55 am
by Slick Fan
I dunno, I don't think I've ever had sticking calipers make noise...they just make the brakes drag & wear the pads prematurely...sometimes warping the rotors in the process.
Who knows though, I suppose anything's possible. But, of course there's plenty of noise when they go metal to metal.
I'm still guessing wheel bearing. It's hard to diagnose then sometimes with the tire off, they make more noise with the car's weight on them. I had a 4x4 S-10 that had a bad wheel bearing for about 18 months, only in the last couple weeks did it really start making death noises...the kind that made me think the tire was gonna leave me one day.
Then I fixed it.
Posted: September 29, 2007, 6:55 pm
by shawns fords
if your brake caliper is sticking, you might get a noise, if the piston itself isnt moving inside the caliper, as well, your brake caliper slides need to be lubricated with disc brake caliper lube, thats what I would check first, you take caliper off, clean up your slides they are actually probably the pins youll take out that hold the caliper on, the caliper slides along them and it gets grimey in there, anyways, clean them up, lube then with disc brake caliper lube and put back on the car, have someone step on your brake pedal once its back on and watch the piston move inside the caliper, once its clamped down to the rotor, it will not move back out really far. if the piston isntm oving at all then youll need to rebuild them calipers, or buy rebuilts or new from part store, if you havent ever rebuilt a brake caliper before then pay a mechanic to do them, or but rebuilt or new. I would just lube up them slides first and go see if its fixed. you might want to clean up the small section where your pads fit into the caliper, should have a small retainer on bottom of one, clean them up also, and put a dab of the caliper grease on there also, dont get messy with the grease lol dont want it on the rotor, ths grease helps everything slide along really nicely.
the shaking is probably your rotors pulsating because they are warped (lateral runout) if thats the case youll need to have them machined and replace your pads anyways
Posted: September 29, 2007, 11:45 pm
by willy3486
I will clean and lubricate them. That may very well be the problem . I didn't know they slid on them. the slides/bolts that hold it on are tight. I don't see how they could allow anything to slide. It is really hard to turn them and ones they are loose they will not slide easy. That very well sounds like what is going on.
Posted: September 29, 2007, 11:49 pm
by shawns fords
they will not turn, the caliper will slide sideways on them pins, you tighten them down good like they should be ( should be a tourque spec in the manual) and the caliper has holes them pins run through, the grease allows the caliper to slide back and forth on the pins, so as the pad wears down the caliper can move easily along the pins the caliper has to move for this reason and to allow piston to tighten up when pressure is applied, I cant tell you how many times ive found this to be a cuplrit on a car for all sorts of problems, because folks clean all the grease off or it was never done correctly at brakes plus or just brakes or wherever they were done, lol
Posted: September 30, 2007, 9:14 am
by willy3486
I figured out what you were getting at shawn and tried it. The bolts slide on the shaft. That area was really tight. It moved really freely after greasing it. It helped some,Its not as loud as it was. But its still there some. I am begining to wonder if the rotor is warped like it was posted. I am just trying to get it to last a short time until I can get a different one. This car has almost 2k on it and it would probably cost me about half of a decent used car with low miles to get all the bugs worked out. then you would still have a 200k mile car I think a mechanic could drive and listen to it and tell exactly whats wrong with it. I just can't explain exactly to the detail it needs to be explained. It could be the wheel bearing but I am hoping not. I would probably have to pay for that and I really don't want to when I am trading it off in a few months. . I had one guy that was a so called "buddy" that could have easly looked at it. I use to do a lot of freebees fixing his computer. Even giving him parts and rebuilding a few for him. But when I needed a copy of a wiring diagram he said he could get it. He had one that was two pages and he never even got it for me. He just put me off. So needless to say I don't help him anymore. You live and learn.
Posted: September 30, 2007, 6:47 pm
by shawns fords
willy, if you have a dial indicator and a magnetic mounting base you can check the rotors for lateral runout. just put the base on a solid section on the knuckle, and put the indicator so it is pointing towards the rotors surface from an outward position, then set it to zero, turn your rotor and see how much the needle moves. if its warped more than 0.006 youll feel it in the pedal and wheel when braking, you wont hear that but its definately going to be your pulsating. another thing to check on the noise, which im guessing at, could be the brake pads retaining spring either worn out or missing, it will be a small deal somewhere aroudn the area your pads slide into the caliper. if thats gone then you hearing the pad flopping around in there because there isnt anything to retain it steady
Posted: October 11, 2007, 3:18 pm
by willy3486
Well I had it checked out. IT turns out the bearing in the transmission where the CV goes in is bad. Not really worth fixing at this point. The mechanic said I may be able to get by with it until the spring if lucky. I am currently looking for a Ford Ranger extended cab. I probably will get one from 95-2003 model year.
Posted: October 11, 2007, 7:34 pm
by shawns fords
wow! I dont think ive ever have had one like that, I guess it would sound the same as the wheel bearing, being as its still the same load, just on the opposite end of the shaft, glad to hear you found it.
