1958 Air Cleaner To 1965 2wd F-250 Cab
Posted: July 13, 2016, 6:06 pm
by chris401
Anyone running this cleaner on there FE powered slick? It won't clear my cab with the intake and carb spacer combination I have now.
Re: 1958 Air Cleaner To 1965 2wd F-250 Cab
Posted: July 13, 2016, 7:00 pm
by FarmMotorSports
I have a yellow one like it I always intended to put on my 292....
Cam bearings rolled before I got round to it.
Posted: July 13, 2016, 7:45 pm
by chris401
FarmMotorSports wrote:I have a yellow one like it I always intended to put on my 292....
I would probably fit on a small block or Y block. It does fit on top of the 1959 430 MEL mocked up in my F-100.
Posted: July 14, 2016, 8:31 am
by FarmMotorSports
The paper filter for that air cleaner. (small)
Gives me some doubts about it's use on a performance engine,
or anything over 302CI.
Unless you're going to modify the bottom for more internal height.
Posted: July 14, 2016, 10:34 am
by chris401
FarmMotorSports wrote:The paper filter for that air cleaner. (small)
I thought it would be ok for just driving around, however when I checked the math the element is too small like you said. Even the 352 at 4000 rpm the 9" element needs to be 2.70" tall. Stock element it's about 5/8" too short.
For what it's worth a 292 @ 5500 rpm needs about the same filter area (62.98) as a 352 @ 4500 rpm.
Posted: July 14, 2016, 11:25 am
by robertrpeak
This is the one I'm running, believe it was off an 63 Merc Marauder. Have a K&N type washable filter in it. It clears but is pretty close, had to rebend a brake line from the MC.
Robert
Posted: July 14, 2016, 2:06 pm
by chris401
Robert
What intake are you using? I am running an Edelbrock SP2P with a Holley on top of 2 1/4" tall 4 hole spacer.
Posted: July 14, 2016, 2:38 pm
by robertrpeak
I'm using an Edelbrock Performer with a Edlebrock 750 carb and an 1" spacer..
Robert
