T5 conversion to use in 66 f100.
Posted: August 20, 2016, 1:15 pm
by 64 f100
After looking everything over once I set the motor, I've decided the best thing is to convert the t5 with an S10 tailshaft. I need to know what all I need off an S10 transmission to make this work, and what is normal or how much can I get the parts for? Will any S10 tail work or does it have to be for the 4.3? Any does and don't , or does anyone know where I can get an article on how to do this. I have never taken a t5 apart before. Don't have any books that show how. I've considered buying one of the discs or books off evilbay for this, any suggestions?
Re: T5 conversion to use in 66 f100.
Posted: August 22, 2016, 9:39 am
by 64 f100
Hello, anybody out there?
Posted: August 22, 2016, 10:31 am
by orangeRcode
A lot of folks were at SS this weekend. Hopefully someone will have some info for this week. I'm interested in doing this as a future upgrade on my truck.
Posted: August 22, 2016, 12:51 pm
by mercuryv8
Posted: August 22, 2016, 1:12 pm
by Gritsngumbo
I have two tail shafts that I'm "fixin" to swap, so that info is appreciated.
Posted: August 24, 2016, 8:40 am
by 64 f100
It looks as if the biggest problem is the speedo gear on the tail shaft. It looks as if, you have to make a bushing to move the speedo gear to locate it on the shaft where needed. Besides the housing you will need the shifter rod from the cap.
Posted: August 24, 2016, 8:32 pm
by unibody madness
I found a guy on the east coast that supplies parts for the t5. I used the s10 tail cover,shaft and overdrive gear he supplied and it all worked out. I also used alumnium tape to shim my son's gear and it seems to have worked out as welll
