Best method of pulling an FE and trans?
Posted: October 27, 2016, 10:25 pm
by Mojave922
I'm hoping to pull my '65's 352 soon along with 3 spd manual.
Is it best to pull them as a unit, or pull the trans out first and block the rear of the engine against the crossmember? Looks like the weight of the engine is heavily biased toward the rear, judging from the location of the motor mounts.
Thanks much!
Re: Best method of pulling an FE and trans?
Posted: October 27, 2016, 11:33 pm
by Michelle
The transmission is hard to pull by itself. I have found it best to pull both at the same time if you are planning on pulling the engine too. You can pull the tranny by its self but more than likely you will have to either burn or grind off the rivet heads that hold the cross member in at the front of the transmission.
Posted: October 28, 2016, 6:27 am
by bruceandersson
Its very easy to pull both if you pull the front clip or at lease the rad support first. Otherwise you have to lift them high and at a high angle. I've never found it hard to pull the transmission separately, but all the transmission supports I've run into are just bolted in.
Posted: October 28, 2016, 6:35 am
by Mojave922
bruceandersson wrote:Its very easy to pull both if you pull the front clip or at lease the rad support first. Otherwise you have to lift them high and at a high angle. I've never found it hard to pull the transmission separately, but all the transmission supports I've run into are just bolted in.
My crossmember (attached at the rear of the trans) is bolted in as well. Pulling the trans first sounds like the route for me. How did you support the back of the engine when the trans was pulled?
Posted: October 28, 2016, 10:07 am
by 64 f100
I use a small hydraulic jack under the bellhousing. Once the tranny is off you can pull the jack. You most likely would not have to support the bellhousing, but if you don't and have bad motor mounts you might have a problem. Tranny can be pulled with the engine without removing front end, but I would just drop the transmission first.
Posted: October 28, 2016, 10:48 am
by Michelle
Let me rephrase what I was saying. Manual transmission can be removed no problem, I was referring to an automatic that I removed from a friends 66, with a non detachable bell housing. We had to grind the heads of the rivets off to remove the cross member that is under the front of the transmission, the rear cross member is bolted in and is no problem to get out. I am getting ready to install a C6 tranny in my truck now and I will have to grind the rivet heads off to get the C6 in the truck without removing the engine. Sorry if I confused anyone.
Posted: October 28, 2016, 5:41 pm
by LM14
I always pull engine/tranny together. It's just easier if you have a good hoist. That way you can take it apart without lifting while lying on your back. Easier to put back together that way, too.
Posted: October 28, 2016, 9:23 pm
by slick4x4
Posted: October 29, 2016, 9:33 pm
by 6166 Junkyard Dog
Michelle, Just ask Chris about grinding those rivets on his Crew
Posted: October 29, 2016, 10:38 pm
by Michelle
6166 Junkyard Dog wrote:Michelle, Just ask Chris about grinding those rivets on his Crew
Your right about that Tom, I will never forget that evening. We made a real party out of that afternoon when the guys were pulling that tranny.
Posted: October 30, 2016, 4:28 pm
by 62bigwindow
If your crossmember is bolted in and can be removed then I'd pull the engine and trans together. Put them back the same way too. I put a full dressed y block and a T85 OD in my 56 wagon as a unit. No problems at all. A engine leveler is a must to do this. It will allow you to get the angles necessary to pull or put it in. I got mine from Harbor Freight for a decent price.
