Spindle/Ibeam king pin hole alignment issue
Posted: November 1, 2016, 2:43 pm
by slixtyfive
Just curious if anyone else has had problems with the angle of the king pin holes on the spindle compared to the I-beam? When I slide the bearing in between the beam and the spindle everything is snug without slop but the king pin won't go through both. It will go through and fits snug without the bearing in place (which allows the spindle to be tilted slightly for alignment) but not with the bearing in place (when the snug fit holds the spindle at a specific angle).
So basically the angle of something is off - either the pin hole angle or the mating surfaces of either the spindle or the beam. I need to look at the mating surfaces closer to see if anything is obvious there. This is a disk brake spindle change out on twin beams but the other side went together fine.
I had new bushings installed and reamed and the king pin fit is good individually(in just the spindle or just the beam). It doesn't seem like a bad bushing installation/ream could cause this but maybe??
Re: Spindle/Ibeam king pin hole alignment issue
Posted: November 1, 2016, 5:47 pm
by LM14
When that happened on my race car spindles, the spindle body was bent. Could have been hit in that wheel at some point in it's life or been ditched hard.
Posted: November 2, 2016, 8:54 pm
by Toyz
Umm, if "slixty-five" refers to the year of your slick, keep in mind that the '65 uses a one year only beam . The difference is in the lock pin area, so should not directly affect the fit in the bore, but may have been "tweaked" since the other side fit.
Posted: November 2, 2016, 9:08 pm
by slixtyfive
Yes, the truck in reference is a '65 but the beams are not the '65s.
And for reference, I had previously installed a different set of spindles on these beams(without this problem) but pulled them off back in May for a different 'more urgent' project......
Posted: November 2, 2016, 9:24 pm
by Toyz
Pretty well brings it to "what Steve said"!
Posted: November 3, 2016, 11:52 am
by slixtyfive
Could be. I personally took these spindles off the donor and had no problems getting the king pins out. I would expect that to have been rather challenging if it is bent.
I'm also not so concerned with the cause as I am about how to address it. I'm thinking if I 'clearance' the mating surface (probably where bearing sits on the spindle) a bit to allow for an angle adjustment to allow the king pin to slide through.
Posted: November 3, 2016, 12:42 pm
by bruceandersson
Would a slight chamfer on the kinpin end allow it to self center w/o the potential of introducing any looseness?
Posted: November 3, 2016, 8:54 pm
by slixtyfive
I got to looking at the bearing and tried a different one from another king pin set that measured about 5-7 thousandths thinner and that gave it just enough wiggle room to get the king pin in. It was a little tighter than the other side but I will give it a try and see how it goes.
