The Best $25
Posted: November 15, 2016, 9:22 pm
by 9Fingers
I have spent on a tool in a good while.
Picked up a small needle scaler this past Saturday. The air compressor is loud and the tool is loud, but I wore inner ear plugs and outer muffs to squelch the noise. This made relatively quick work of the thick frame paint over rust. It doesn't get it down to bright metal like a sand blaster, but it gets the paint, any loose rust scale and leaves a surface that can be wire brushed more easily.
Re: The Best $25
Posted: November 15, 2016, 10:56 pm
by slick4x4
I've always wanted to try one of those
Guess I'll buy one since you endorsed it !
Re: The Best $25
Posted: November 16, 2016, 11:31 am
by Michelle
Looks like a handy tool.
Re: The Best $25
Posted: November 16, 2016, 3:00 pm
by slickstysix
Harbor Fright?
Re: The Best $25
Posted: November 16, 2016, 3:48 pm
by T-Bone
I've also found them to work great on removing undercoating/bed liner!
Re: The Best $25
Posted: November 16, 2016, 5:23 pm
by 9Fingers
Yep, it was from harbor freight. A few drops of oil down the air fitting and dont crank the pressure over 90psi. The noise was the worst part, but with double ear plugs its bearable. The needles eventually rounded over some after a couple hours use, but a touch on the grinding wheel squared them off again and gave them more bite.
Re: The Best $25
Posted: November 17, 2016, 8:01 am
by shipwrecked
Ugh...
Re: The Best $25
Posted: November 17, 2016, 3:46 pm
by orangeRcode
I've seen them before at HF and wondered if they worked at all or not. I may pick one up now. Thanks
Re: The Best $25
Posted: November 18, 2016, 12:42 am
by foodstick
First I started laughing thinking of those fake Harbor freight adds !!!
Then I was looking at that tool trying to figure it out as I have never seen one before.. Then it dawns on me.. it must work just like one of those party favors that if you blow thru them hard enough they straighten out and shake the streamers on the end..
This thing is like a steel high pressurized party favor that the streamers beat the surface until something gives...
And now I am laughing about the fake Harbor Freight adds again !
Re: The Best $25
Posted: November 18, 2016, 10:27 am
by unibody madness
I picked up an old school needle scaler years ago, never thought to use it on our truck frame.
I redid an old Greenburg fire hydant in the eighties with it, and it worked great. If you push too hard it bends the needles ,not hard enough, it barely works.
Re: The Best $25
Posted: November 18, 2016, 3:41 pm
by LM14
Used to do a lot of stick welding, great for slag. Also great for cleaning burned on carbon and on old cast iron parts. If you do a weld repair on cast iron you can use a die grinder to rough up the weld surface then use the needler to blend the weld into surrounding metal.
Re: The Best $25
Posted: November 18, 2016, 9:30 pm
by shipwrecked
About 7
Years ago, on one of the ships I was assigned, we had to use needle guns to clean off deck plates. It was the worst week of my life.
Re: The Best $25
Posted: November 19, 2016, 8:03 am
by slick4x4
shipwrecked wrote:About 7
My father in law was in the navy
He told me almost the same story
1950s ... They dry docked the ship
2 guys per team , hanging off the side
Running those needle scalers all day
Re: The Best $25
Posted: November 19, 2016, 11:58 am
by Gritsngumbo
I first heard of them as a solution to remove undercoating and/or soundproofing. Seems I've used one, but don't remember if I bought it or borrowed it. I haven't seen it in my shop unpacking, so must've borrowed it.
