f100 drums on f250 spindles
Posted: April 6, 2017, 8:43 pm
by ezernut9mm
am i correct that i can put f100 front drum assemblies on f250 spindles? the f 250 spindles are 1966. the f 100 drum assemblies i am looking at are 1970.
Re: f100 drums on f250 spindles
Posted: April 7, 2017, 11:33 am
by chris401
My 65 F250 and F100 use the same spindles. I do not know about the 70.
Posted: April 11, 2017, 4:06 pm
by ezernut9mm
Thanks for the reply chris. I will do some digging.
Posted: April 11, 2017, 10:25 pm
by 6166 Junkyard Dog
Chris the spindles are not the same for F-100 and F-250 WRONG,WRONG 65-67 F-100 are the same and 65 to EARLY 71 where used F-250 came with 2" shoes and then on 2 1/2" shoes was only on 66-67 trucks only NOW on 68-early 71 F-250 spindles where the same Disc or Drum,, Now Chris the drums cannot interchange due to the size of brake shoes unless you change the spindles/ backing plates etc.. I guess
Posted: April 12, 2017, 2:13 pm
by chris401
6166 Junkyard Dog wrote:Chris the spindles are not the same for F-100 and F-250 WRONG,WRONG 65-67 F-100 are the same and 65 to EARLY 71 where used F-250 came with 2" shoes and then on 2 1/2" shoes was only on 66-67 trucks only NOW on 68-early 71 F-250 spindles where the same Disc or Drum,, Now Chris the drums cannot interchange due to the size of brake shoes unless you change the spindles/ backing plates etc.. I guess
I think you misread my post. The backing plates are different but they bolt up to the same spindles. I discovered this when I restored my 65 F250 suspension. I suggest you measure and mock a F100 65/66 spindle to your 65 F250, just like I did.
As for the 65/66 year the spindles right and left are the same.
EDIT: Some merit to 61-66 Junkyard Dogs comment. There is a spindle id difference between kingpin bushings. 65 nylon bushing is different from the brass bushings. I installed nylon bushings and 8 months latter I had my spindles reamed for brass bushings. Reguardless of this they are still the same F100 to F250 2wd twin IBeam axles for the 65 year model. I recomend to anyone that replaces kingpins to have your spindles fitted for the brass bushimgs. This has no effect on the original post.
Posted: April 18, 2017, 1:48 am
by Alan Mclennan
Yes but why Ezer, why wouldn't you just get the complete stub axles with disc brakes off a 79' F100 and be done with it.... Kind Regards.. Concerned !
