Rocker arm adjustment question
Posted: November 6, 2017, 11:58 am
Over the weekend I put in new lifters, push rods and rocker arms on my straight 6. I don't know if its a 240 or 300. VIN says 240 but the late date code on the block has me thinking it may be a 300.
Here is my problem. The nuts on the rocker arms keep backing off. The new rocker arms came with two nuts and the paper inside the box states: "The two nuts packaged are for early (3/8") and late (5/16") applications."
My rocker studs take the smaller nut. And the small nuts provided aren't oblong like the bigger ones for the early motors.
Do I just tighten them all the way down? Is it that simple? I was going through the process of finding TDC, finding zero lash and then adding about a half a turn. Ran great but after just a minute or two of idling, several started backing up.
When I took the old ones off, they nuts were tight, and once loosened, they just came off by hand. They weren't tapered. So I am thinking these aren't adjustable and I just run them all the way in.
Any help is appreciated. Thanks.
