horn works now!
Posted: May 14, 2018, 12:20 pm
by Jerry D
Just to keeps new posts coming, I thought I'd relay a story about my horn fix this last weekend...
For the first 22 years I owned my truck, I used an aftermarket horn button below the dash, wired directly to the horn. Last summer, I re-wired the truck, taking most of the summer to do it. When I finished the wiring, the horn worked through the contacts in the column, so I bolted the steering wheel on. Once on, the horn didn't work. In that it was the end of summer, and I just wanted to drive it, I didn't worry too much about debugging it, since it was being put away for the winter shortly. Fast forward to this spring, and this last weekend, I decided enough was enough. I pulled the wheel, only to measure and figure out that the contact was too short. I had two different length contacts, and the short one was below the wheel, and the long one through it. So, I swapped locations, and after installing the wheel, found the short contact wouldn't fit through the hole in the wheel. My wife unknowingly donated a nail file, and after about 10 minutes of filing, the contact fit. Reinstalled the horn spring and button, and presto-walah, I have a working horn on the column for the first time in 23 years!
Re: horn works now!
Posted: May 14, 2018, 1:44 pm
by slick4x4
"Better late than never"
Re: horn works now!
Posted: May 14, 2018, 5:41 pm
by Mr. Jones
30 yrs.later my 350 still has no horn,probably just as well.....not pissing people off.....I'd be blowing that thing every 30 seconds in this town......
Re: horn works now!
Posted: May 14, 2018, 5:43 pm
by unibody madness
Good going... I rebuilt or modified the horns/steering wheels on two of my Unibodies. both worked great. now the horn honks when I have the turn signal on and turn the corner????? It seems to be grounding when the contact point touches the signal cancelling flippers.
Re: horn works now!
Posted: May 15, 2018, 3:56 pm
by Day 2
BEEP BEEP :mrgreen:
Re: horn works now!
Posted: May 16, 2018, 10:18 am
by slixtyfive
Madness's comment about the horn honking when he has the turn signal on reminds me - have you all seen the video where a guy 'pranked' his buddy by wiring the horn in his car to the brake pedal??? Hilarious!!! :D
