Timing - plug gap?
Posted: June 15, 2018, 8:21 pm
by redstone65
After putting in the new HEI distributor the engine seems happiest at about 12 degrees btdc at idle. If I gap the plugs open more (currently .032) could I bring the timing down a bit? It’s a 50,000 volt coil.
Re: Timing - plug gap?
Posted: June 15, 2018, 9:28 pm
by FarmMotorSports
Any HEI in good shape even with a stock coil should work well with a .045 gap. Larger gaps may be acceptable with platinum plugs or other premium plugs...
Usual symptoms of to much gap is burnt rotor, cap or both(.060)... way too much gap will usually cause high rpm misfires(.080). Basically the larger the gap the more frequent your service of iginiton parts will be.
And I'll step away from the timing light... should, maybe... I'm not going to predict what will work for your truck and your driving style...
Posted: June 16, 2018, 1:03 am
by redstone65
Thanks for the info on plug gap. I’ll bump up to .045 and see how things run.
My driving style is very grandma. I don’t drive fast at all, and the vacuum advance seems to be working fine. Just felt like 12 degrees seemed a little high but maybe it’s fine for this engine at this age. I know my TDC is spot on. I went back and re-marked it today with a run-out gauge.
Posted: June 16, 2018, 8:36 pm
by Toyz
Pretty much what FMS stated!
Good luck with your wires and wide plug gap! With one exception; IME, "HEI causes high RPM misfires!" Anyone one old enough to have worked with an oscilloscope and distributor machine has seen that exact phenomenon.
To me, "50,000 volts" is like a 160 mph speedometer on a Pinto- sounds good but nothing but potential for trouble.
Posted: June 16, 2018, 11:15 pm
by redstone65
Toyz wrote:"HEI causes high RPM misfires!"
How "high" is high?
I gapped them up to .045 tonight and took about a 30 minute drive to the grocery store and back. Some stop and go, and some 55 mph streches. Ran really good. I think I'll stay at this for about 500 miles and check the plugs and rotor to make sure nothing funky going on.
A little clip of it running. You can ignore that lifter clicking.
VIDEO
Posted: June 17, 2018, 7:21 pm
by Toyz
4400 rpm is the point of extreme spark "spatter" as noted on scopes.
As FMS noted; the life of the components is the big issue, especially with what appears to be thinly insulated plug wires.
The original applications used 8 mm plug wires and .060" plug gap, moving the "weak spot" to the rotor and cap, often resulting in "burn-through" to ground, not to mention the effects of the additional heat on the "all-in-one" unit.
Another issue worth mentioning is the incompatibility of the drive gear with the camshaft material on the "offshore" units as well as extremely poor ( or lack of) quality control resulting in oil pump drive failure.
Is there such a thing as an efficient after-market HEI?
Certainly! Performance Distributors sells one which addresses ALL HEI issues, and when compared with some of the known, documented, "offshore" units, could prove quite a bargain in the long run.
Now, to the inevitable, "I've had mine for x years with no problem", ask yourself why GM saw fit to
a) separate the coil on six cylinder designs,
b) "deep six" the design for such engineering feats as the Optispark and "crab-trap"!
As far as initial timing (vacuum source plugged); if it is "happy" at that setting, with no perceptible indication of pre-ignition with your normal choice of fuel, I'd leave it there.
The inherent degrees of dwell available on a six cylinder allow plenty of "build time" and the slight increase in total timing may help mid-range economy and performance.
Posted: June 17, 2018, 8:28 pm
by FarmMotorSports
Quality wires, quality plugs, and .045 gap your good for lots of trouble free miles...
