slip yoke leak
Posted: June 26, 2018, 9:19 am
by redstone65
I'm going through and replacing all of the leaking seals and gaskets in the engine and drivetrain (did timing cover this past weekend). I noticed yesterday the slip yoke seal on the trans extension housing is leaking pretty bad. It's a 3.03 trans. Is that a readily available part?
Re: slip yoke leak
Posted: June 26, 2018, 5:01 pm
by slick4x4
Should be ... just a seal
Re: slip yoke leak
Posted: June 27, 2018, 9:20 am
by unibody madness
While you are at it, my drive line guy put my yoke on a lathe and polished it, now no need to worry about eating up the new seal.
Re: slip yoke leak
Posted: June 29, 2018, 10:06 am
by Lowell
Not sure about your tx ,but I think mine has a bushing behind the seal. its best to replace it while your at it,if its worn, the new seal won't last long.
Re: slip yoke leak
Posted: June 29, 2018, 6:51 pm
by Toyz
Lowell wrote:Not sure about your tx ,but I think mine has a bushing behind the seal. its best to replace it while your at it,if its worn, the new seal won't last long.
Yep, that is the likely cause of seal failure.
