can't remember how the wires go on a ds2. only 2 wires that I remember but can't remember which wires to hook up to power.
also does an e core coil need a resister?
duo spark 2 wireing
duo spark 2 wireing
1961 F350 pick up
1962
1963
1964
1965
1966 F350 camper
1962
1963
1964
1965
1966 F350 camper
greentruck
Re: duo spark 2 wireing
66 f100 4x4 ,64 f100 4x4 ,65 f100 2wd, 76 bronco, 74 bronco, 68 bronco, 69 mustang mach 1,68 torino gt,42 ford gpw
best I can tell you do away with the resister wire and run a full switched 12 volts to the coil and brain box. just gotta find a coil that dosent need a resister. mine must have needed one cause only made it about two miles and truck went dead.has ran for years useing the pink resister wire for power to the coil then noticed the resister wire was getting quite hot so I bypassed it and probably burnt the coil.
well after studying this diagram all I need is a coil with a built in resister I think. this is almost how I have it now
1961 F350 pick up
1962
1963
1964
1965
1966 F350 camper
1962
1963
1964
1965
1966 F350 camper
