1966 f100 custom cab short bed 428 c6 automatic empty weight
Posted: December 10, 2020, 8:21 pm
by SLICKCOLLECTOR
3950 lbs
Re: 1966 f100 custom cab short bed 428 c6 automatic empty we
Posted: December 10, 2020, 8:52 pm
by SLICKCOLLECTOR
SLICKCOLLECTOR wrote:3950 lbs
i was surprised. that is with a PI aluminum intake the rest is factory FE. Iron CJ heads. "A" scratch block. i did not think they weighed that much. i hauled 20 clean radiators to the local scrapyard.and the empty truck with me in it weighed 4140. and i weigh 190. so the empty weight is 3950. i was guessing more around 3600. i am going to Heartland Park this next summer and see what 600 horsepower will turn in the quarter with around that same weight.. When will this end.
jim
Posted: December 11, 2020, 4:01 pm
by aarons428
My 65 F100 with my aluminum headed 428 short box with my suspension mods weighed 3450 without me in it.
Posted: December 16, 2020, 1:26 pm
by SLICKCOLLECTOR
how many lbs do you think you removed from front end modifications over factory? aluminum heads probably make 50 lb difference over cast iron. i have a spare probably 30 lbs or so. maybe a few more brackets than yours and a power steering pump etc. but i can't see that big of difference. i have long mistrusted the owner of the recycle place. i should have weighed the radiators on a feed scale prior to going there. too late now.
Posted: December 16, 2020, 1:42 pm
by slick4x4
a full tank vs 1/4 tank of gas will make some difference
also tires & rims can make a difference
4spd trans vs 3 spd ....
Posted: December 16, 2020, 3:20 pm
by SLICKCOLLECTOR
aluminum turbine wheels . i will check the tank. i just drove it to the scrapper after cleaning the radiators and loading the truck. so i'll edit after i gain some more complete information. bucket seats .interior carpet. truck has had disc brake conversion from 73-79. power steering and power brakes. front bumper and contour bumper on back.
jim
Posted: December 16, 2020, 3:41 pm
by unibody madness
Not sure it makes a difference but my 61 long bed uni w/cast iron 460,C6 with bench seat and front I beam w/ a full tank, empty cab came in right at 5000lb
Posted: December 16, 2020, 4:13 pm
by aarons428
SLICKCOLLECTOR wrote:how many lbs do you think you removed from front end modifications over factory? aluminum heads probably make 50 lb difference over cast iron. i have a spare probably 30 lbs or so. maybe a few more brackets than yours and a power steering pump etc. but i can't see that big of difference. i have long mistrusted the owner of the recycle place. i should have weighed the radiators on a feed scale prior to going there. too late now.
It's hard to say but cast iron Ibeams are pretty heavy. Plus I ditched the rear leaf springs in favor of some homemade ladder bars and airbags. I weighed mine at a trucking facility so I'd say it's pretty accurate.
Maybe weigh one of your trucks that you did the crown vic swap on to get and idea of the weight difference.
BTW I'll be in Eudora Monday and leaving Wednesday morning and I'd like to take one of your vic swapped trucks for a drive and see how i like it!! If that's possible.
Posted: December 17, 2020, 7:49 am
by SLICKCOLLECTOR
aarons428 wrote:SLICKCOLLECTOR wrote:how many lbs do you think you removed from front end modifications over factory? aluminum heads probably make 50 lb difference over cast iron. i have a spare probably 30 lbs or so. maybe a few more brackets than yours and a power steering pump etc. but i can't see that big of difference. i have long mistrusted the owner of the recycle place. i should have weighed the radiators on a feed scale prior to going there. too late now.
ain't no problem. i'll be around. virus an all has me staying home. seven eight five five four two one thousand. careful on the roads. btw i also have 1/4 tank of gas.
