Rear brakes and backing plate
Posted: December 12, 2007, 10:12 am
by don luster
Need some of you help again. Thanks for being there. My 63 slick is getting the disc brakes for the front from speedway. Well now the rear end will need better and wider shoes. I think my 9 inch rear end has the 28 spline axles but not sure. My question is what later backing plates with wider shoes will work. Thanks for all the great help. I also decided to keep the 223 engine for a while since it runs so great and very low mileage. Don
Posted: December 12, 2007, 10:50 am
by The Big M
Have you seen this article from the Technical section?
http://www.fordtruk.com/index60.html
Posted: December 12, 2007, 11:01 am
by don luster
How do you go to the technical site.
sorry to be soooo dumb but don't see any tech site at the top. Thanks for posting that is what I need. Don
Posted: December 12, 2007, 11:23 am
by Ford4jack
Don
Click on Fordtruk.com Home at the top of the page then hit the technical link
Lots of good stuff there.
Posted: December 12, 2007, 6:54 pm
by banjopicker66
I understand you had a good teacher on the axles to use, too. :lol:
Posted: December 12, 2007, 8:03 pm
by STYLN63
I used a 9" Versailes rearend on my slick years ago. Wouldn't do that again but I do have a great suggestion...
I have done this twice now and love the results. I paid $60 for two complete set ups from the junk yard. We put one set on my father's model A (with 9' Ford) and one on my 89 f150 (8.8 rear). This set up will work on 8.8 rears as well as big tube 9" rears.
'95-'01 (check years with local junk yard for interchangability- '94 may be the same too!) Ford Explorer and Rangers. Ask for backing plate,hoses,rotor,caliper,bracket and all hardware. This set up will also include your parking brake set up. You will need a cable adaptor from Lokar to complete the e-brake hook-up (part #EC-81FC) $32.69 from Summit Racing. Good Luck.
Posted: December 13, 2007, 2:13 am
by STYLN63
You know, I didn't metion that you will need a master cylinder for 4 wheel discs also. Roughly $39 from NAPA. You can get it from any vehicle as long as you have 1 1/8" bore. I used a 78 T-Bird w/ disc option. You DO NOT have to have power brakes on your truck to make this work.
Posted: December 13, 2007, 8:14 am
by fmartin_gila
I believe the need for better brakes on the rear is unfounded, all the rear brakes do is keep the rear end back there as most all the actual braking is done with the fronts. When I put disk brakes on my 62, all I did to the rear was use the hardware kit to make them self adjusting.
Fred
Posted: December 13, 2007, 11:49 am
by 65TremecGT
I had a 68 parts truck and my slick needed brakes bad so when i did my disc swap on the front, i went to the 68 and later style wider rear drums, since i had the axles and good drums, was a cheap swap! Stops great now, now I have to work on its motivation, because that sux right now!
Posted: December 13, 2007, 12:33 pm
by STYLN63
I don't know if it is possible to have too much braking power. Believe me, with a 545 cu in engine and full pro-street chassis I like to go fast...but it is even a better feeling to be able to stop it. Even with a I-6 or small V-8 under the hood; it is good to stop. Especially if it is a daily driver. Remember, you are competing against rice rockets that way half as much, stop twice as fast, and have a quarter of the stopping distance...and quite possibly are being driven by a young kid who has no financial obligation to care about their car and don't have time to signal because they are ingrossed in a deep conversation about "are you sure Billy really likes me"? It is a cheap insurance policy to convert to discs in the rear. Remember that the future maintainence of your braking system will be cheaper and easier.
That's just my two cents worth...
Posted: December 13, 2007, 8:27 pm
by 64fordf100292
so your saying that a rear disc setup from a exploder or ranger will work on our 9" rear ends???? arent the rearends in the ranger and exploder 8.8"s?? is ther any modifiing that has to be done????
Posted: December 13, 2007, 8:54 pm
by STYLN63
Yes sir. The 8.8 and the big tube (big bearing) 9" housings (found on 28 and 31 spline set-ups) have the same flange at the end of the tube. Direct bolt-on to the housing.
Posted: December 13, 2007, 9:55 pm
by jkimbrel65
That is a nice peice of info to have Thanks :D
Posted: December 14, 2007, 10:22 am
by 64fordf100292
cool. now heres another question. the bolt pattern for the rotor is the 5x5.5"""
Posted: December 14, 2007, 10:23 am
by 64fordf100292
as you can tell from my name, i have a 64 f100 with a 9". are the 9" forthat yr truck the big end/big tube?
Posted: December 14, 2007, 12:37 pm
by Slick Fan
That's definitely something I didn't know, love this site. :D
Rangers & Exploders have a 5 on 4 1/2 bolt pattern (same as Crown Vics BTW), so the rear rotors would have to be drilled (?) for the larger pattern...or just swap all four corners to the smaller bolt pattern.
Posted: December 14, 2007, 10:34 pm
by Shawn F.
Kind of old thread I know but will that rear end work under my 66 stock 9 inch then as well? I plan to convert the whole thing to 5 X4.5bolt pattern so I can run a different wheel (coy wheels).
