new carb
Posted: January 11, 2008, 6:07 am
by mexbearlll
could someone give me some insight as to a replcement for a new 2bbl carb to replace my damaged 1 bbl, with manual choke, without to much hassle. thanks
Posted: January 11, 2008, 10:02 am
by The Big M
What size engine?
new carb
Posted: January 11, 2008, 10:01 pm
by mexbearlll
223 I 6
Posted: January 12, 2008, 1:54 pm
by MadMaxetc
If you are using the stock intake you will have to have an adaptor made. You could probably use a small 2bbl off of a small V8, Autolite or Motorcraft. I have a used 1bbl from my old 223 that you could have. It may need cleaned and rebuilt, but it might have some good parts to fix yours or vise versa.
Posted: January 12, 2008, 2:26 pm
I have wondered about using the 2 stage 2bbl from an early 80s 4cylinder on a 223, it had a secondary like a 4bbl.
Posted: January 12, 2008, 4:25 pm
by MadMaxetc
Greg D wrote:I have wondered about using the 2 stage 2bbl from an early 80s 4cylinder on a 223, it had a secondary like a 4bbl.
That would be a cool idea.
Posted: January 14, 2008, 1:22 pm
by MadMaxetc
Hey, I found some more info on the Carbs I have....
They are (2 of them) MC2100.
I need to see what CFM they are, but here is the chart.
Bore... CFM
0.98....190
1.01....240
1.02....245
1.08....287
1.14....300
1.21....351
1.23....356
1.33....424
When I get a chance I am going to see what it would take to make one of there work on a 223.
