Dropped front of my slick
64kust
Post by 64kust »
hey everybody jus wanted to share that dropping a truck by yourself is not as easy as it sounds,,,i spent my superbowl sunday in the cold rain all nite long with a few wrenches n a couple of jacks,,,,would have been way easier with air tools but nobody could help me yesterday,,,,so i did it alone,,,1st time ever doing anything like this,all i knew was how it was supposed to look like in the end,,,i put the springs under the axle,pic in my photos
jakdad
Post by jakdad »
Well, you certainly missed some good movies........................
Jim
frank66
Post by frank66 »
looks good! what do you have planed for the rear? or do you like the raked look?
64kust
Post by 64kust »
movies???
thanx man, i dont know,
its a tough choice because both ways look good,,
maybe when i get tired of the raked look ill slam the rear too,,,
i thought it was gonna an easy job to do,,,man ive never turned a wrench so many times in my life,,,,
in a few days im getting my smithys glasspacks welded on, then when it heats up some do the body work and paint it
Shawn F.
Post by Shawn F. »
Do you have any pictures of it lowered now? We need some if you don't. :D
If you did the 3" Dream Beams then the raked look will look fine IMO. The dream beams IMO do not drop these trucks much at all so it's not a major problem with rake. The back tire tucks under the bed side wheel well anyways which makes the back look lower in the first place.
Johnny Canuck
Post by Johnny Canuck »
Um Shawn, how did he get the springs under the axle of a twin I truck :shock:
and
[albumimg]3602[/albumimg]
[albumimg]3604[/albumimg]
you could simply look under his profile for his pics.
Looks good Kust,, I think I would drop the back down some though if it were my truck. How's it steer? :shock:
64kust
Post by 64kust »
yeah did it with all stock stuff the only thing i had to buy were the longer U-bolts heres the before and after,,$20 in parts and some hard
before: http://fordtruk.com/forums/album_showpa ... er_id=1043
after:
http://fordtruk.com/forums/album_showpa ... 043#TopPic[/img]
64kust
Post by 64kust »
handles just the same EXCEPT for when i hit a pothole it feels like the wind just got really strong
64kust
Post by 64kust »
hey whats a twin i truck??? :?
shawns fords
Post by shawns fords »
twinn I bean, ( twinn I) looks great, I think you might want to forget about help from your buddies and do it yourself, lol I never ask for help anymore and just do it all by myself, i've become quite a Hermit. and very un-sociable but things get done rofl lose alot of sleep on work nights being out there until 11.12 pm because I forgot what time it is, then I find myself taking 6-8 month breaks and catching up with friends and movies, then back at it.
this is the good side
Comet
Post by Comet »
I'd take a couple leafs out of the rear at least to drop it a little. It will still have a healthy rake, just not look like it's going to fall over itself.
Twin I Beam suspension. Replaced the solid front I beam (single) axle.
Shawn F.
Post by Shawn F. »
So wait did you do the twin I beam drop or is it a single I beam with leafs and you just flipped the leafs on it?
I am confused now. Sorry I did not see the pics and even look at his gallery.
Post by Gritsngumbo »
Shawn F: He has a 64 which has a Single I beam front axle.
Phil
Post by Phil »
Compared to a 62, can I do that or should I just pull a few leafs?
Shawn F.
Post by Shawn F. »
Thanks for the info. It looks great BTW. That is how low I want my 66 to sit so I will install my dream beams and cut a coil off my springs I guess to get it like that or close to it. My camber is already too much positive which is a bit odd because most of the time if they are off then camber is too negative. Not with mine. :D
[quote="Shawn F."]Thanks for the info. It looks great BTW. That is how low I want my 66 to sit so I will install my dream beams and cut a coil off my springs I guess to get it like that or close to it.
Shawn thats what I did to Lenore,
[img][albumimg]3073[/albumimg]
Alan,
ezernut9mm
Sweden
Post by ezernut9mm »
i will assume the rear of your truck is basically the same as a 68 since i can't remember what the rear hangers looked like on my 64, but to lower the rear of my 68 3" i did a "half flip" of the front hangers. it only costs about 12$ for grade 8 bolts, nuts and washers.
just a thought. oh, i did need to shim the rear end 4* i beleive it was.
shawns fords
64kust wrote:yeah did it with all stock stuff the only thing i had to buy were the longer U-bolts heres the before and after,,$20 in parts and some hard
after:
how about a shot of the undercarriage itself?
64kust
Post by 64kust »
ill post up pics of the underside in a lil bit when i get my camera from work,
The Big M
Post by The Big M »
64kust wrote:handles just the same EXCEPT for when i hit a pothole it feels like the wind just got really strong
Sounds like it handles poorly.
I've seen photos of a 57-60 with an axle flip, but it had a c-notch in the frame for clearance, a relocated steering box to reduce bump steer, and a piece of channel welded to the bottom of the axle to act as a spring pad.
Keep in mind that you've now completely changed how your front end reacts to steering, suspension, and braking input.
