Page 1 of 8
my 62 uni build
Posted: February 7, 2008, 9:04 pm
by twistedfreak
New to the forum so i thought id join and show off the uni and try to find so new ford friends,ideas an parts.
heres some picks of the build so far coming along nice for the first straight axle truck and classic i must say. going a little different route but going to with the classy lines that made me buy this rod.
Posted: February 7, 2008, 9:05 pm
by twistedfreak
Heres some more picks of the uni
Posted: February 7, 2008, 9:10 pm
by twistedfreak
Posted: February 7, 2008, 9:11 pm
by twistedfreak
And lastly the gas tank
Posted: February 7, 2008, 9:20 pm
by Johnny Canuck
Fascinating. Not quite sure how that front suspension setup is gonna work but sounds like you do. Sharp looking truck once you are all done. Love the Sankey Keg.
Posted: February 7, 2008, 9:27 pm
by twistedfreak
Thanks its going to work just like a linked rear end but its going on the front. the lower bars keep the axle from shifting front to back and a track bar will stop it from tracking side to side and the coil overs will be mounted from the lower bars to the hoops that im making now behind the wheels. im hoping to get picks of it this weekend as soon as my bushings come in so i cane tig those in to mount everything and i have a buddy making me some wedges for the pitch of the axle so its the same and the straight axle. sounds hard but its really simple
Posted: February 8, 2008, 1:02 pm
by Slick Fan
That's a different approach to a front suspension, I'm looking forward to seeing how this one turns out.
The Uni looks like it's in pretty good shape, welcome aboard.
Posted: February 10, 2008, 8:00 am
by Gary Seymour
Welcome to the site. There is always good information and ideas here. I have a '62 uni sb like yours. What front disc brake set up do you have on there? I am going to go with a dropped front axle with spring eyes reversed to get mine down. What did'nt you like about the stance using the dropped axle? I hope you post some pics of the new front end.
Posted: February 10, 2008, 9:28 am
by twistedfreak
I didn't like the fact that with going with the 3" axle and taking all the leafs out it didn't really lower it that much and left the axle 1.5" off the ground and roads in Ohio really such , so that wouldn't have worked out too well. as far as the disc brakes i went with speedways kit very simple to install and priced right. the only way to get the stance i wanted was to flip the drop axle and go that way but then i didn't have very much travel.
Posted: February 10, 2008, 9:32 am
by twistedfreak
twistedfreak wrote:Heres some more picks of the uni
the top pick is with the drop axle and the leafs blown apart with only 2 and thats the stance it left hardly any drop at all and reversing the eyes would only give me about a 1 to 1.5 more
Posted: February 10, 2008, 9:54 am
TF, nice truck! So are you using the drop axle with this setup then?
Gary, front discs are pretty easy basically an afternoon job if you don't need to do the king pins.
http://www.fordtruk.com/forums/viewtopic.php?t=2647
Posted: February 10, 2008, 2:16 pm
by twistedfreak
yep going to be a little different well see how it works out, but i think it will be just the way i imagined it to be so ill post picks when i get the bushing in and installed. im using the speedway front disc brake conversion also.
Posted: February 13, 2008, 8:36 pm
by twistedfreak
well here they are the picks that everyones been waiting to see, including myself because im pretty happy with the way it turned out.
Posted: February 13, 2008, 8:43 pm
by twistedfreak
Posted: February 13, 2008, 8:45 pm
by twistedfreak
now all im waiting for is the coilovers and the front suspension can be taken back off and powder coated and the track bar made.
Posted: February 13, 2008, 9:33 pm
by Garbz
How are you dealing with the torsional forces developed when the wheels arc up and down independent of each other?
Neat setup.
Garbz
Posted: February 13, 2008, 10:08 pm
by twistedfreak
are you meaning the up and down motion of them. with the range that they move the geometry doesnt change that much and once the track bar gets installed it will lock in place, the coil overs only let it travel 3-4"
Posted: February 14, 2008, 12:06 am
by Comet
Are you going to put some kind of a stop or lip on the arms where they attach to the axle/U-bolt? I'd hate for those to slide out if the u-bolts loosen.
Posted: February 14, 2008, 5:46 am
by twistedfreak
they have a 5/16 allen for an alignment set screw just like on the leafs.
Posted: February 14, 2008, 1:42 pm
by The Big M
I would suggest extending the links slightly and using two u-bolts each (four total), just to be safe.
What's the wall thickness on that tubing?
How much caster change do you expect the axle to see throughout its travel? I can see that being a potential issue. Also, I believe what Garbz was getting at with his question was whether or not there will be any bindng when one coilover is at full compression and the other at full extension. That's something you may want to find out and address before powdercoating.
I'm interested to see where you end up mounting the coilovers and panhard bar, and how it all works together, so keep us posted. Should be a cool setup.
