66 F100 Gas Tank relocation and filler tube door
Posted: February 18, 2008, 10:11 am
by jerryking72
I have seen many how tos on relocating the tank to the rear of the bed. Ive already prepared the rear of the frame to accommodate this. I just cant get over the idea of having the filler tube coming up the center of the bed. I had seen a post some time ago speaking of relocating to the tube to the drivers side tail light. Has any one successfully attempted this? Any suggestion on a different method, with details, would be appreciated.
gas tanks
Posted: February 18, 2008, 10:54 am
by Truckrat
Jerry, I don't think I have seen that trick. Sounds like a great way to hide it, but sounds like a bit of fab work to hinge the taillight housing. I'd like to see that trick. What tank are you using?
The Bronco tank has gotten popular for a rear mounted tank, and is available through Gas Tanks.com brand new. They also have all the parts you need to hook it up. Check Item F10A or F10B. The only difference is the filler hole size. 23 gallon tank. TR
Posted: February 18, 2008, 5:44 pm
by ras4434
1950's Ch---- had the tail light that flipped down. That was one of the things I did like about the 56 210 I had. I always wanted to fab one for a slick but stink as a fabricator. I'd buy one....................
Posted: February 18, 2008, 6:07 pm
by FORDMANLCRACKEL
Here is what i did.
[albumimg]811[/albumimg]
[albumimg]810[/albumimg]
Lonnie
Posted: February 18, 2008, 7:35 pm
by Hoofbeat Racer
That looks great Lonnie, might just have to try that 8)
Posted: February 18, 2008, 9:26 pm
by Rosati
I'm actually doing this now. I started this weekend putting the bed back on and getting the tank pulled back down. I'm using a Cougar tank so the top of thank sits just under the bedcrossmembers. the filler neck is right under the support at the 3rd set of bolts from the cab.
I intend on taking pics as I go, but it may take awhile to get them posted.
As far as the tail light, I'm planning to make the entire assembly tilt out and hold in place using a 1/4 turn type fastener. the hinge will be welded in, but the pin will be easily removed when needed. I have it in my head but it won't be realized fro at least a week.
Posted: February 18, 2008, 11:07 pm
by 66fordtrucknut
Wow, Lonnie, looks great! Nice shop BTW, Did you fab your tank? I build tanks all the time for boats, aluminum and stainless.
Charlie
Posted: February 19, 2008, 1:45 pm
by FarmTrk
Lonnie:I really like the looks of your filler location. What kind of tank did you use?
Posted: February 19, 2008, 6:31 pm
by Choppermike
Here is what I used. A 49-52 Ch*&% car gas tank. Fits between the frame rails perfect. Can still use my hidden hitch and the filler is to the side instead of on the top. The tank comes from Tanks Inc. an includes everything but the sending unit. It also gives you the option of carburetor or FI
[albumimg]3753[/albumimg]
It is 16 gallon and is only 7.5" tall so it doesn't hang down so far. The filler fits nicely through the opening between the frame rail and the bed floor.
[albumimg]3757[/albumimg]
For the gas door I chose a late model Aerostar because the gas door locks and is cable operated from the cab. In my case I plan on using a trunk popper solenoid hidden behind the rear tailight.
[albumimg]3755[/albumimg]
Open View
[albumimg]3754[/albumimg]
This is what is on the interior of the aerostar and it should look sort of stock like in the bed.
[albumimg]3756[/albumimg]
This was just my best option. I would be glad to share details with anyone interested. I do have a new Bronco II tank I was going to use but on my particular build it hung down too far. Make someone a deal on it!
Choppermike
Posted: February 19, 2008, 7:42 pm
by FORDMANLCRACKEL
Thanks guys. Yes i built it myself from 1/8 steel. It holds 42 gal. I dont like to stop for gas very much. Below are some pics.
http://picasaweb.google.com/lonniecradd ... 8817436130
http://picasaweb.google.com/lonniecradd ... 4587239922
http://picasaweb.google.com/lonniecradd ... 6062076418
http://picasaweb.google.com/lonniecradd ... 4846324274
http://picasaweb.google.com/lonniecradd ... 0616128066
http://picasaweb.google.com/lonniecradd ... 2090964562
Keep in mind i have a 3" body lift so i had plenty of room between tje bed and chassis.
I like the way Choppermike did his also. He did a good job. I have seen his on his personal album.
Lonnie
Posted: February 20, 2008, 5:52 pm
by Choppermike
I appreciate all the pm's for more info on my tank install. I will try to get more pics soon.
Mike
Posted: February 20, 2008, 8:30 pm
by Phil
I <3 this thread
