lowerin' front
Posted: February 24, 2008, 12:23 am
by 63lokinup
Hello guys, lookin' at lowerin' the front, now i think i got the part about removing some leaf's out of the leafsprings, i don't understand about turnin' them over, could anyone explain, i'm sure some one will, and is it the same on the rear springs? 1963 stepside.
mark
Posted: February 24, 2008, 9:42 am
To do reverse eye springs you have to take the main leafs in to be re arched, if you pull 3 leafs out you won't be able to do this because you will limit your suspension travel too much. You can have your axle dropped or buy a drop axle from CenPen with either spring modification though. Be sure to check your caster if you mess with it at all though, you might need more shim.
