engine question/gas supply
Posted: March 12, 2008, 5:50 pm
by willy3486
Well guys my daily driver truck runs fine but I still have a few issues. You guys helped me pinpoint the line issues to the carb. This was the 91 Mazda b2200 . It drives fine now until I get about 1/2 tank of gas in the tank. Then sometimes it will start the crap it was doing before,slowing down when I give it gas to pull on the interstate ,not going up hill good. It started doing that and I filled it up, no problems after it was filled up. Its not as bad as before when I replaced the hoses from the fuel pump. But heres what I found out. I looked at the gas tank and where the gas filler tube you put gas in and the rubber hose that goes from it to the tank the clamp had broke. Plus the other hose that goes into the filler tube that is smaller, I think it is to let the vapors go back into the tank had a crack in it as well. So what I did was to put a new clamp on it and then move the hose with a crack in it up closer so I could clamp it below the crack so it wouldn't have a air leak. My question is this, from what I fixed today I think it was not sealed good and would let pressure release. Will the tank not being able to keep sealed properly cause it to act sluggish when the tank gets 1/2 full or less? I am thinking it might. What do you guys think? Thanks in advance.
Posted: March 12, 2008, 7:24 pm
by blackagatha
1st, if there was a crack on the hose, there are probably more. Replace ALL the fuel line hoses.
I dont know anything about your truck in particular, but I think that a tank pressure problem should not change at half tank. Now if a hole somehow developed in the pickup line inside the tank, it could start sucking air when it gets exposed to air.... Again, I dont know if the maz has anything like this, but I figure if something like that developed in a stock slick tank, it would explain similar issues. Now how to diagnose something like that.... I just dont know.
Well, if you were to have the tank out of the truck, fill it about 3/4 full of water, gas, or something of your choice, and seal off the filler port, then flip it upside down and put a bit of air pressure to a return line port, it may cause gas to squirt out the pickup line, if its coming out of a crack.
I just thought though, you would have to use something, perhaps a chunk of bicycle innertube on a rifle brush to ram into the pickup tube to plug the end to keep the airpressure from coming out and negating the experiment.
I know, lot of work/guesswork to try to figure it out. Maybe somebody will have a better idea.
If it is in fact a problem with a pickup tube, I dont know how you could go about replacing it...
Posted: March 13, 2008, 7:08 am
by Ford4jack
Willy you might try changing the fuel filter and see what kind of crusty's are in the old one.
My thoughts are if it has a bunch of rust in the filter the upper part of the pickup tube in the tank might have rusted enough to get a pin hole or crack in it.
You could try pulling the fuel line off the carburetor and running it into a can or bottle then start it for 10 or 15 seconds and see how much fuel you get.
Do this full vs empty and see if there's a difference in the volume of fuel.
Posted: March 13, 2008, 8:21 am
by jwh f-100
Yes definatly atleast inspect all the lines thuroughly. Replace the filter/filters and see what may be in the old filters. If you are at the fuel level where it is acting up do ford4jack's test then when it is pumping maybe try dumping 5 gallons in it and hopefully you can see the inprovement.
I did a search on a tank sender for your truck this is what i found.
Like ford4jack said it could be a rust pin hole. From looking at the photo maybe it is split where bent or split at a point where the tube is tacked/welded to the fuel guage sender. Could be the pump also.
All just thoughts, start with the small stuff, good luck.
Posted: March 14, 2008, 11:21 am
by willy3486
Thanks for the replys. I put another clamp on and pulled that hose up as a temp fix until I can get the hoses and time to put them on. I drove it for the last few days and got to about a half a tank today. I wanted to fill it up before the weekend. Anyway it ran fine. When I took the gas cap off I could hear the rush of air from the tanks pressure. It had never done that. So I am thinking that was probably the final issue. I plan on all new rubber hoses from the tank to the cab when I do replace them.On a positive note I am getting 27.2 mpg with this last fillup. Each time I fix something it gets a little better. That within about 2 miles of my car I had. Most I ever got with that was about 29.5 mpg.
