weight of a tractor tire.
Posted: March 31, 2008, 8:49 am
by willy3486
This is for people familiar with tractors. I have a international 404 tractor I had to take the rear wheel to have fixed. I had a leak around the valve stem. I am wondering about the weight of the tire and rim without the water or calcium in it. I did a search on a aftermarket tire and found one that is a 12 by 28 rim at 65 pounds. I was wondering a rough weight of the tire itself. The weight of the tire,rim and water or cacium in it when I took it was about too much for me to deal with. But I think it probably had anywhere between 200-500 pounds of water in it. I am thinking about picking it up in the bed of my truck instead of having to take off early from work to get my trailer. So does anyone know roughly what a tractor tire might weigh for a 12 by 28 rim? I asked the guy to not put in any water or calcium. I told him I would worry about that when I get home.
Posted: March 31, 2008, 11:34 am
by Ford4jack
Willy at a guess I would think the assembled wheel would weigh at least 300-400 lbs without fluid kinda depends on how many plys and how much tread there is though.
Its more than you would want to dead lift for sure. I would think the guys at the tire place would load it for you. I bet they could guess the weight fairly close also.
You probably already know this but when you go to put the tire back on the tractor a pick type pry bar is a handy way to line up the bolt holes with the hub if yours has lug bolts.
If yours has the spin to adjust type rims a bit of ranting and raving might be in order. :lol:
Posted: March 31, 2008, 12:35 pm
i have a set of airplane tires on rims 14.5 x 22.5 14 ply. i can barely stand them up to roll around. cannot even lift even the ones without wheels.
Posted: March 31, 2008, 1:03 pm
by Ford4jack
Funny how tires can fool ya we got some solid ones in for a loader at the perfume factory* those things weighed 1600 lbs each and were only about belly high.
* The perfume factory was the dreaded landfill recycling building.
They had people going thru household garbage for recyclable materials there.
Tin building summer heat service calls were a bitch there :barf: X 10
Posted: March 31, 2008, 9:51 pm
by Doug
I live on a farm and have dealt with a lot of tractor tire/wheel combinations. I recently had a 12-28 repaired on my IH 350 utility which is about the size of your 404. When you say "rim" I assume you mean including the center disc. I would guess the tire at 70 lbs, the tube at 15 lbs, the rim and disc at another 75 lbs. When you add ballast, that's a whole 'nother ball game. Water is about 8lbs per gallon and calicum more than doubles the weight of the water without adding volume. A tire is usually filled level with the top of the rim leaving an air space from there on up. I think this solution adds about another 300 lbs to a 12/28. Your tire dealer should be able to tell you exactly how many gallons of balast your tire holds at 80% fill and the added weight. Bottom line is if your wheel is empty, 1 guy can handle it. If it's loaded, get a lot of help. If you are rolling a loaded tire and it starts to fall over, just get out of the way. It will hurt you! Don't ask me how I know. If your local dealer can't give you the numbers, E-mail me and I'll give you the number of my local farm tire shop. Good Luck--- Doug
Posted: March 31, 2008, 10:12 pm
by Doug
willy-- here's another side note-- leave the ballast out unless you really need the traction. Even a small leak is very corrosive to your rim and the water makes the tire a lot stiffer and more prone to damage from things like sharp rocks and small stumps. Your tractor will even ride better on rough ground. A lot of dealers are getting away from handling calcium, and tractor manufacturers now recommend wheel weights only.
Posted: March 31, 2008, 10:38 pm
by Ford4jack
I think your rite Doug a 12 x 28 is not that big of tire guess I go fishing to much. :wink:
Posted: April 1, 2008, 8:22 am
by willy3486
Thanks for the replys. I asked them not to put in any ballast in it so I didn't have to put that weight in my daily driver and so I wouldn't have to lift it. I picked it up with my 4 banger mazda and it rode fine. I had taken it Sat. and left it to be fixed. I may take that water out of the other side. I think it has the calcium in it and I don't want it to rust the rim like this one is. It had the metal eat out bad by rust around the stem. The tractor is fairly heavy and where I use it is mainly flat. Plus I use it mainly for bush hogging and gardening. I took it off Friday night and it was extremely heavy. I took the center piece that mounts to the axle off and just left the rim on the tire. I rolled it to my trailer about 5 feet away. It was all I could do to get it on there. And the bad part on this is that I broke or cracked some ribs a couple of weeks ago. Then after I got back Sat. I noticed the weight on my bumper had warped the recycled dog food can metal they made the bumper out of. I will have to get that back into shape. Its not so bad that it can't be used as is. The problem I have with "buddies" is unlike a lot here I don't have any good "buddies" My problem has been you get to be friends with someone and help them out and then you need a favor and you no longer have a "buddie". I helped out a guy that our kids and wives became friends first. I rebuilt computers for him,give him all types of parts and even got a hard drive for the dude. I probably did about 10-15 hours of free work for him in a 6 month period. Then I needed to get a copy of the 2 page wiring diagram on my slick. He was a authorized Ford mechanic and could get them for free. He wouldn't do that or even offer to lift a finger for me on anything. Same thing with family. I helped family members for years. When I need anything they run and hide like cockroaches when the light is turned on. I had one relative that needed help. I said I would help but he would have to call me when he got home one day. He didn't know what time he would get home that day and just wanted me to come and wait if he wasn't there. I didn't want to wait at someones house if they wasn't there. He was too cheap to make a 25 cent long distance call and then complained to relatives I wouldn't help him. I have got to where I just do things by myself.
