rusty gas tank question
Posted: April 3, 2008, 7:57 pm
by willy3486
I got a question on gas tanks. I think I have finally solved my problem on my daily driver. I had trouble today with it again and bought a fuel filter. Well to make a long story short the gas in the line from the tank to the filter was red from rust. But the filter had done a good job and the line from the filter to the carb had clean gas. I blew through the old filter and sure enough it was mostly clogged. So my plans are to get a new tank and another filter. But in the mean time I have to drive it to work. But I am thinking of dropping the tank and cleaning it out this weekend before the tank gets here. Will this help about the rust untill the new one gets here? Also if I do clean out the tank this weekend do you think it will stay clean enough to wait to replace the tank the next weekend. That would be the best senereo for me to wait until the weekend to replace the tank.
Posted: April 3, 2008, 8:24 pm
by blackagatha
well, how long has it lasted you already? I think if you clean it out it will at least limp you out that long. Or you could just drive something else for a few days...
My only thing is that if you go scraping out huge hunks of rust, you're liable to make a big ol leak.... Kinda like what happened to all the ancient water pipes in tucson when they introduced the CAP (central arizona project) clorado river water. They switched from nice mild ground water, which had allowed the pipes to get all rusty, over to CAP and I guess it might have been a wee bit acidic or something. About 6 months to a year after the switch, everybody with an old house wound up having exploding water pipes. (we woke up one morning when I was about 7 to the sound of my dad ripping the wall out in the kitchen with a claw hammer, after he found water dumping out of the wall when he went out to make some coffee...) the house predates any real known history. My grandparents bought it in the 50's, and nobody knew anything about it even then, it was just a little plastered Adobe (burnt dirt and straw) house in the middle of the desert. Probably about the same era as /related to the Fort Lowell facility about a mile away, a big adobe military post from the civil war I think...
Posted: April 3, 2008, 8:26 pm
by Alan Mclennan
Willy, If your got anew tank on the way and its only one week away I`d disconnect the fuel line and give it a bit of a flush through and just put another filter in.
Alan,
Posted: April 3, 2008, 9:27 pm
by willy3486
Ah yes Arizona. I love it there, I lived in Tuscon a few years as a kid. Anyway I want to try to get it to at least get me back and forth to work until I can hopefully replace it next weekend. I did replace the fuel filter this afternoon. I may have to take it off this weekend to see what kind of tank it is. These trucks they put electric fuel pumps in some and some had engine mounted mechanical pumps. The two types had different tanks. The engine has been swaped out to a mechanical but the truck originally came with a electrical pump. So I may drop it to see what type it is and drain the rusty gas out.
POR15 fuel Tank sealer kit
Posted: April 3, 2008, 11:44 pm
by shawns fords
of these kits and found out I will need 2 of them to finish the job. when it showed up I started to clean it up per the instructions and once I ran the cleaner through first time around ( use boiling hot water when mixed) the parts that I got cleaned came out like new, unfortunately the kit is for a smaller tank so I didnt get enough cleaner to finish the job. so I need to buy one more kit and get it back out and finish that up. once you are done cleaning ( you mix the marine cleaner with hot water and fill tank let it sit then turn tank to other side, wash it out and repeat until clean) the metal inside comes out looking brand new, then you fill it up and swash it around with the metal prep, then the por tank sealer.
Just another idea than having to buy a new tank. It will take a weekend to do the job thouroughly
Be Patient
Posted: April 4, 2008, 2:27 am
by oldtrucks
willy3486
I did a write up on gas tank cleaning a few months back. Here it is again. I have done this with many tanks with very good results and it won't break the bank.
Start by removing the tank and draining it. If you can take it to a car wash, a radiator shop or a friend that has a steam cleaner and wash the tank out as good as you can. Next stop by the store and pick up a box of dish washing soap. The kind used in automatic dish washers. Dump it in the tank and fill the tank with hot water and let it set over night. Go through the above steps until the tank is clean. Once it is clean dry it completely. I use a heat gun a hair dryer will work almost as good. I turn the heat gun on and blow the hot air into the the filler neck. Be careful the tank will get hot. Next I use the blue colored metal prep available at the parts store and I slosh it around inside the tank until its completely coated, dump it out and dry the tank again. Thats it. Of course if you find leaks during this process repair them if you can.
I haven't found the need to use sealers but that is a decision you will have to make.
Posted: April 4, 2008, 8:07 am
by Ford4jack
Willy here's a couple of thoughts on this
I would think that its had a rust problem for awhile and another week or two would be ok.
I would bet a Mazda truck is not famous for there use of thick gauge metal so it might stir up
a hornets nest of problems to mess with it.
A second thought is have you priced a fuel tank yet. My little import truck had a leak on the bottom of the tank so I priced a new tank it was 400+ dollars.
So it might be worth cleaning and sealing it up also
I just patched mine with epoxie for the time being but I intend to find a plastic tank to replace it with someday.
Posted: April 4, 2008, 10:43 am
by Shiny
Yeah I wouldn't stir up any $hit in there at all. Leave it and put your new tank in.
On cleaning tanks what I've done is used muriatic acid to clean it out. Then washed it with hot soapy water, dry it really good with a heatgun, then use the metal prep and POR 15 gas tank sealer. Works like a charm.
-Shiny
Posted: April 4, 2008, 11:45 am
by willy3486
I priced a new tank today and it was only 114 bucks. Its a small tank and I went ahead and ordered it. I can return it if needed. I may have tried to clean or fix it but I have had it to act up so often I thought it was a cheap fix to just replace it. And adding I am about 80 miles round trip to work I just didn't want to wind up on the side of the road some afternoon or morning. This makes about the 3rd tank I have had to go out in different vehicles. The first two I found out after they leaked out the gas in them. Nothing like pin holes in the tank draining 50 bucks of gas on the ground overnight.
Posted: April 6, 2008, 1:30 am
by blackagatha
ha. My dad was getting my grandpa's 48 foot coachman motorhome ready to sell after he passed away in 99. He put a full tank of diesel in it (about 100 gallons) and when he got home discovered that the filler hose was shot and was leaking bad. AND that there was about 50 gallons ABOVE the hose, it was an aftermarket extra capacity tank, with stock filler location. SO he changed out the top connection first, then yanked the hose off the tank and slpped his hand over it. Then traded on the new hose. Took a nice Diesel bath... probably 2-3 gallons all over him...
Yeah I know, that was barely related, but I wanted to share a story... Back as you were!
Posted: April 7, 2008, 3:54 pm
by willy3486
Update on the truck. I got the new tank and tank filter in over the weekend. It runs really great. Better than it ever has. But it was interesting to look inside the tank. Someone had been in there before me. I could tell by screws gouged out a little. It looks like it had done the same with them and they just replaced the internal filter. The tank had some rust in the bottom but did not look too bad. But the filter had worked and was full of rust. No wonder why it wouldn't run. So I am glad I got the new tank. I would hate to go through pulling the tank again. I would easily pay 150 bucks not to do that again. I know what you mean by the bath in Diesel. I wore a chemical mask for auto painting to keep from breathing it. It really helped but I did get some on me. I got sick from that mess. I am better now but I hate to deal with that crap. I get sicker than a dog dealing with gas. My wifes car probably needs the same thing done to it. I am trying to talk her into having it fixed by a mechanic while we are gone to Atlanta. That is if I can find a mechanic around here in the boondocks that actually knows what a gas filter is. Thanks for all the replys over the last few months I think I finally have all the bugs out. The way it runs I bet I can get at least another 150 k miles out of it.
by willy3486
