Gettin a 86 f150..
Posted: May 13, 2008, 4:07 pm
by clevor347
So family problems moved the tables on workin on my 66... i'm gettina 86 with fuel injection for 300. it cranks for 30 minutes then cuts off. what could be the problem? i'm guessing something with the electronics? it has a 302. i'm gonna put my 85 5.0 h.o. in it.. maybe lower it.. i just need somethin to get on the road with for now. would the 85 mustang block or the 86 truck motor be better to build?
-clevor
Posted: May 14, 2008, 7:54 am
by FORDBOYpete
1st You need to determine if it's electrical/ignition or fuel based problem. It could carry over to your replacement engine too you know?
It could be a TFI or Ign Module, it could be a weak fuel pressure relay, it could be a weak or worn fuel pump, a bad pick up or pick up screen, especially if they ran E-85 or ethanol in a Non Flex Fuel engine, or it could be your Ign coil, or that stupid slider "buss type" remote ignition switch, is on the way out. What sort of fuel induction does 86 F-150 have? Is it CFI (Throttle Body) or Carb?
Also What are you calling an HO 5.0L ? 85 HO Mustang would have been carburated 4V engine.
Lincoln Mark VIIs & very late (March/ July) 85 & up Towncars came with early Roller Engines & were a product of SVO, but I don't remember them calling them HO. Perhaps LSCs were called HO, but not in the Town Cars. Roller Engines are way different. The LSC would be an early SEFI-TP/ EFI and the Town Car a CFI also called Throttle Body injection.
Point is there is little or no difference in the 5.0L engines with CFI or carb.
The carburated 5.0L is virtually the same block but has different internals as the CFI engines. I believe all CFI 85s still had that lame die cast oil pump assy tho.
I Hope this isn't too confusing
FBp
Posted: May 14, 2008, 3:31 pm
by clevor347
The truck is a cfi.. But my 85 motor came outta a mustang, and is 4v carb, i'm thinking about switching the motors out.
Posted: May 15, 2008, 7:52 am
by FORDBOYpete
Clevor,
Okay, the 4V Mustang 5.0L carb & 86 Truck CFI 5.0L engine are basically the same engine, except truck version is cammed for the Speed Density logic of a CFI ECM & probably uses a TFI Ignition. So you'll have a net improvement in performance when you put it in your F-150.
All the "hardparts" stuff like the Bell Hsg, Trans, Exhaust, Engine Mounts, Various Accessories like P/S pump, Alt, A/C, et all that will bolt up since all your brackets interchange between both engines. You'll need to lose the Catalytic Converter it negatively affects a carb engines' performance.
You'll need to use Ign system out of the 'Stang. If F-150 Ign switch is still good it will work with a carb type set up engine. But you'll have to fab up wiring for a Carburated version. You need not to bother hooking up ECM & wiring used for a CFI engine. BUT you'll have to figure out the gauges if you want gauges that work.
Just make sure you can get away with a retrograde in your state if you have a vehicle inspection and criteria there for meeting E-Legal standards with the 86 F-150 when you're done. If so you may not be able to register it with that retrograde conversion. I know it won't fly in a lot of states.
Otherwise it will be a easy change over technically speaking and a lot of make do / busy work to get it done, in my opinion.
FBp
