No such thing as a free puppy or car (long story)
Posted: June 3, 2008, 6:10 pm
Okay --
So my father-in-law had this 1995 Mercury sable. Leather, cruse, power everything, nice all around car. Couple of things were known to be wrong. One being he had left a six pack of soda in the car the exploded on a hot day, so the inside needed a very good cleaning. The other was blown head gaskets. So they give me the car and I tear into the top end of this car. I pull the heads, have them machined, do all the service put it back together. Once I got it back together I could not get the trimming right to save my sole. So I ended up taking the car down to my buddies Shop so they can get the trimming right for me and re-check my work.
Well I got a call from them and Tom (my friend and owner of the shop) says "Josh, have you seen the bottom of the engine?" Long story short the bottom end was BAD. It was so bad infact that the timing cover had to be cut off the block because it had seen so much heat, and the bearings were down to the copper. So he thought it was worth fixing so I went ahead and told him to do it. So at the end of it all I pretty much had a fresh engine. I called up my father-in-law and asked him if he knew it was that bad, and he said well he was driving the car to all the different shops trying to get a quote on the blown head gaskets, he even told me he did take the car on the highway in that condition... Had I known that little tidbit of information would have been helpful back when I got the car from him. Anyways...
So Driving the car for about a month and started to notice I am having a hard time shifting from 1st to 2nd. I got the car home and pulled the trans pan and found attached to the magnet huge chunks of metal. I mean massive in size inch and a half and longer. I am no tranny guy so I again take the car down to my buddies and they give me the low down that the tranny is going out. They could pull it and and troubleshoot it and try to fix it, but sometimes it's just cheaper to pull it and put a new one in.
So we pulled the tranny, but in a newer rebuilt one and away we went. The day after I got the car from the shop, I am at the gas station filling it up, when I was coming out from the station after paying I notice a huge lake of coolant under the car. It's not only antifreeze but it's also AC coolant. The gas station I was at was less then a mile from my buddies shop so I drive it over there. We take a look and it is SO weird, all the hoses look just fine on the outside, but we cut into them and they are all warn out from the inside out. It was like the rubber had turned into saw dust from the inside... So we replaced every single rubber hose, had to order the AC ones from Ford and re-charged the AC.
Now I will say my buddy and his Shop really did help. Most people would start to say "Well I would go to another shop". But they have always stood behind their work, and they gave me brakes on the coast of the parts and discount on the labor, really helped me out. They even said the hose thing they should have caught, but they couldn't explain it. The only theory we have is from when the engine got so hot from driving around with blown head gaskets.... I know there are other people out there with worst stories then mine, but I thought I would share. And in the end it's all my fault by not doing a better job on checking out the car before I got it from my father-in-law...
