Small engine question
Posted: June 14, 2008, 2:20 pm
by willy3486
I have question on a Briggs and stratton engine. It is a 6.5hp ohv engine on my wood chipper. I tried to start it today and ran into problems. I tried to pull the string and it would hang up. I cleaned it out and I noticed that gas would pour out of the muffler. I also noticed it would leak by a gasket that was just below the muffler. I did not try to start it after that. As far as the engine goes it has very little use ,maybe 10 hours at the most. But it is a few years old and it has been stored in the dry when not in use. I did not see any cracks and the last time I used it the chipper did not act up. It has not been started in a couple of years so I am wondering is a seal or gasket has dry rotted. Any ideas? It looks a lot like this one at the link below.
http://www.commercialpower.com/display/ ... ocID=76962
Posted: June 14, 2008, 3:12 pm
by 66fordtrucknut
Try here Willy, these guys are pretty good. I had a problem with my splitter, mine wasn't getting gas. Good luck.
Charlie
http://www.hobbytalk.com/bbs1/index.php?
Posted: June 15, 2008, 2:52 am
by uglyblue66
Your float may be bad in the carburator.Or needle stuck open due to this sorry gas that gels up in nothing flat.
The over head valve engine would be able to gravity feed fuel thru the carb,thru the open intake valve and would be able to drip out the exhaust once the cylinder was full.You will need to do some carb work,then remove the spark plug and hopefully get that cylinder dried up,then change the oil as it probably has gas in it now.
Posted: June 15, 2008, 8:33 am
by willy3486
Thanks guys. I will check that out Mack. That makes a lot od sense with it being gummed up. It has sat about 2 years I think. Once I got it started it would always run good. I think I will try to let it drain from the piston this week and let it set until the week of the 4th. I may dig into it then.
Posted: June 15, 2008, 8:58 am
by Slick Fan
You may want to change the oil too, while you're emptying the cylinder. If the cylinder gets full of gas, it's bound to seep past the rings & fill the crankcase with gas. It happens on motorcycles very often, when a carb needle sticks open.
