Ethanol
Posted: July 27, 2008, 10:25 pm
by Ford4jack
Just wondering if anyone is able to get non ethanol gas anymore.
I have been looking in our area and all the stations are 10% mix
Not sure if its a summer time emmissions thing here in TN or what.
Posted: July 27, 2008, 10:48 pm
We have 87 regular, 89 10%, 91 Premium bout everywhere and E85 at some places here.
Posted: July 28, 2008, 6:35 am
by FORDBOYpete
Not around here anymore. Up until Last month we had 1 station that didn't have that 1% to 10% added, but now everybody around here is adding it.
It's not good or maybe I ought to say is bad for some fuel systems as it affects O-rings, diaphrams, and other soft materials.
We had a woman with a Pristine Lo Mileage 93 Buick 3.8 V6 with leaky O-rings @ all the connections on the Hi PSI side of her fuel supply line. Fuel line parts are no longer available @ GM. Parts jobbers don't sell replacements & Salvage yards won't/don't sell used, toxic, GM fuel lines.
Y'all must know if GM Plastic fuel lines catch fire, fumes are toxic enough to cause death if inhaled. There were TSB's, MSDS Sheets & Safety Warnings several years ago when GM went to toxic substance fuel line material. I am not just bashing GM this is real fact. Ask any up to date Fire Department, ADRA, the EPA, and so forth.
We had to re-create the high pressure supply line from Fuel pump outlet at the tank (or tank end outlet) to fuel rail at engine. To do that we cut off "qwik" connect/ disconnect ends & replaced them with ethanol proof flex line that's high PSI safe, plus clamps.
So if you're forced begin using ethanol added fuels keep an eye on older fuel systems for potential leakage. . . .
The Good news is most, but not all 2K (2000) & later vehicles have ethanol & methanol compliant systems, as far as what they are made of. They are by no means any sort of Flex Fuel compliant systems however.
Posted: July 28, 2008, 7:55 pm
by shawns fords
I wonder how heny made it work in his test cars 100 years ago and all of them hot rodders over the years? I run 85% in my new truck and its awesome I have more power and same mileage, of course its a FFV we have guys not on FFV running a 50/50 mix in their 4x4s and its not giving them any fits I bet its that damn southern state moisture conditions causing all of the problems, I remember everything I owned rotted away over night down in them humid states
Damn the GMs and their vaporated fuel lines
Posted: July 29, 2008, 12:03 am
by Ford4jack
Humidity is my biggest concern here in our low useage vehicles.
Tractor,mower etc I like to keep em full but from what I have read the shelf life of ethanol is not that great and the moisture / rubber problems.
Pete thanks for posting about the toxic fuel lines.
Posted: July 29, 2008, 12:47 pm
by FORDBOYpete
Roger on the GM Fuel Lines. . . . . You're 100% right about moisture contamination as one result of ethanol. Alcohol has long been used to absorb moisture & prevent freezing in fuel, systems. However it also imports moisture from atmosphere if there is none in the system. Another famous Boondoggle is ED3S or whatever it was called that had oxidizers they blended into gasoline. That killed good gas in 2 weeks if you didn't use it up & let it sit instead.
Back in the day if anyone poured too much "Gasoline" or "Fuel Tank"Antifreeze"or
Anti Moisture Additive in the tank similar problems occurred. Fuel Pump Diaphrams & Accelerator Pump Daphrams, like on holley & Fo0MoCo Carbs turned into something like black RTV. Pick Up tube Socks collapsed & got hard if they were made out of vinyl. making things worse. Also fuel with the antifreeze added would absorb moisture & become rancid over time if it had a chance.
Major Manufacturers issued TSB's. Challanges got made about doing warranty work on alcohol damaged fuel systems. It was a majot Monkey Goat Rope. . . .and if you ever tried to move a Goat with a rope made out of monkeys you will have an idea of what I mean.
Ethanol does not produce big BTU's (or power) gasoline, or methyl alcohol does. BTU's are what make Power that get mileage & do the job. Adding ethanol to petroleum compromises performance even if vehicle is ethanol rated. MPG will always drop off as the coefficient of fuel efficiency does. If any of you are keeping accurate records you're probably beginning to see the effect already.
New vehicles, those made in last 5-6 years are usually ethanol capable, many are flex fuel rated. It's older vehicles not made to ingest ethanol or methyl alcohol where problems happen. I believe in making stuff better, but we seem to find ways to make things worse instead. In otherwords, not all changes are always for the better.
Hey just my humble take on the fuel rip off we're supporting right now.
FBp
Posted: July 29, 2008, 7:58 pm
by shawns fords
I get more power on E85 than ill ever do with 91 octane, my time slips have shown that, as well as mileage. in hot days my ETs drop from 18.00s to 18.75s on 91 octane compared to 18.00 cold or hot with E85 my mileags is identical on both fuels with better towing power which does not drop. hauling a 3000 lb car on a 1500 lb trailor 120 miles and I had exact same mileage I got without towing.
I also Saved between 1300 and 1500 bucks in one years useage compared to the cost of 85 Octane gasonline
I Bet ill even save more this year with it being NOW 1.20-1.30 a gallon less than the cheapest gasolines at the pumps I was only saving about 60 cents per gallon last year the cost on both has gone up but the ethanol is only 2.60-2.70 compared to 3.99 or higher around here.
Posted: July 30, 2008, 12:03 am
by MrEvil
10% isn't enough to harm anything. It's like saying 20 proof booze is flammable (it isn't). Odds are the people with all the problems are putting E85 in the tank since it's cheaper than regular unleaded in some places.
I had one person make an outrageous claim that 10% ethanol cut their fuel economy in half. My Crown Vic is not Flex Fuel capable and it still gets 20mpg with the AC on full blast and me barrelling down the highways. I think I dipped as low as 18mpg this past week, but I did alot of idling in the car using the Laptop.
Posted: July 30, 2008, 7:38 pm
by ABA
I filled up for the first time in who knows when with this 90/10 gas and I did notice I only got about 260+/- a few miles out of that tank when I had been getting close to 300 miles to a tank.
My friends have reported the same thing. One said his wife's car got 60 miles less to a tank then before the switch.
So if you're getting worse gas mileage and it's not any cheaper than the pure
gas what's the point?
Posted: July 30, 2008, 8:50 pm
by shawns fords
ABA wrote:I filled up for the first time in who knows when with this 90/10 gas and I did notice I only got about 260+/- a few miles out of that tank when I had been getting close to 300 miles to a tank.
if its not cheaper than they are robbing you ALL you need more compression with it to improve your mileage maybe 2-4 deg advanced timing will be just enough. they have been running 10% ethanol here in colorado forever
