Page 1 of 2
heater hose support bracket?
Posted: August 16, 2008, 6:00 pm
by greenindian
Hey, anyone got a solution to a heater hose issue...my 66 F100 with a 352 has two very old looking hoses (feed/return) that not only need to be replaced with new ones but I'd really like to get them away from the alternator. Since this is were they like to rest. Is there a bracket on the fender well that they get bolted through that keeps them tucked up and away from engine/manifold heat?
Posted: August 16, 2008, 6:29 pm
by 66 POJ
Yep. I do not have a pic of it and may have an extra one. I'll look.
Posted: August 16, 2008, 7:30 pm
by 66 POJ
I can only find one right now, maybe the other will pop up tomorrow. It looks like 2 UU's with a screw in the middle.
Posted: August 16, 2008, 9:34 pm
by DV65CustomCab
Ditto, bracket to hold them goes on the right inner fender on my '65.
Posted: August 17, 2008, 12:30 pm
by Slick Fan
Double ditto. Here's a pic of one of them, my '65 is missing the other one. They slip onto the heater hoses facing each other & are held to the fenderwell by one bolt. BackyardResto has a pic of the pair of them in one of his re-plated parts pics.
Posted: August 17, 2008, 4:04 pm
i have several but you will have to wait until after the 25th.
Posted: August 17, 2008, 7:24 pm
I may have a spare straight axle one I can check.too
Posted: August 18, 2008, 5:26 am
by jwh f-100
You can also use a couple tubing clamps..
Posted: August 18, 2008, 9:08 am
by greenindian
Thanks all for the help and pictures.
Posted: August 20, 2008, 12:44 am
by Missouri66
little slow getting this reply posted, but had to work on how to get a picture up. This is a pic of the original brackets from the same model/engine as yours -- 66 F100 352. If you can't find some, you could probably re-create. 2 pieces of sheet metal bent and rolled to fit the hoses and fastened to the inner fender with a single bolt.
Posted: August 20, 2008, 4:38 am
by 66 POJ
Whoa mine might be from another car. Only picture I could find of mine but you can see it is open instead of rapping around the hoses.
Sorry, it too me a while to find the pic.
Posted: August 20, 2008, 11:00 am
by Slick Fan
Yep, yours is from something else. Looks like it works ok, though.
That's an official looking heater valve, BTW. 8)
Posted: August 20, 2008, 5:37 pm
by 66 POJ
Slick Fan wrote:Yep, yours is from something else. Looks like it works ok, though.
I'm wanting to change that while I have the truck tore apart. The original valve, which did not come on the newest '66, appears to be controled by a cable. My truck does not have provisions for a factory cable. The heater knob pulls out but controls a flapper in the heater box. How did the valve work if the truck did not come with a pull cable. Was it a "deluxe" heater?
Posted: August 21, 2008, 2:56 pm
by Slick Fan
I'm not sure, I guess that area of Slick info is another "gray area" in my Slick knowledge. :hm: The reason I say that is that I've never NOT noticed the heater controls hanging under the dash on a '65/'66 (the two I'm most familiar with), of which one of those controls that heater valve...if I'm remembering correctly.
Damn, now I've gotta go look at my Slicks again! :lol:
What say you guys, was there two different heater systems available on these trucks? :dontknow:
Posted: August 21, 2008, 3:06 pm
by jwh f-100
darn, now I've gotta go look at my Slicks again! :lol:
I am curious about this topic also.
My '62 did not have any valve at all. I would like to install a valve I can control from in the cab, if possible. If not I will install some type of ball or gate valve.... I guess I could just get a nice looking cable assembly, install it by the heater switch, and if anyone asks I'll say it is the choke.. :)
Posted: August 23, 2008, 10:57 pm
by Slick Fan
Well, I don't know if these pics will help much, but... :D
Here's the heater valve & cable routing on my '65. The valve has obviously been bypassed because of old age issues. :P
Sorry, crappy pic...I knew I should have waited until daylight. :oops:
These are the controls under the dash. The one of the right marked "temp" controls the heater valve. The left one controls the temperature...how much outside air versus recirculated inside air.
Same thing with my Son's '65. Same with my '66 too, but it's put away. :wink:
Posted: August 24, 2008, 10:28 am
by greenindian
Thanks, I was looking for a shot of the two UU brackets that hold the heater core feed/return hoses on the left inner fender area. I've got a good idea now of what I need. Thanks!
Damon
Posted: August 24, 2008, 12:23 pm
by NmbrDmy
Missouri66 wrote:little slow getting this reply posted, but had to work on how to get a picture up. This is a pic of the original brackets from the same model/engine as yours -- 66 F100 352. If you can't find some, you could probably re-create. 2 pieces of sheet metal bent and rolled to fit the hoses and fastened to the inner fender with a single bolt.
Ford never sold this bracket separately, it ONLY came with the heater/defroster installation kit. I searched thru three parts catalogs, nothing is listed.
THE HEATER WATER VALVE IS STILL AVAILABLE FROM FORD
C3UZ18495A / MOTORCRAFT YG133 (C3UZ-A replaced C3UZ-B)
MSRP: $38.46 / F150partsguy.com price: $23.08
Posted: August 25, 2008, 12:20 am
by frank66
I have the same hose brackets as 66 POJ, but I have 2 of them. I guess they only come on trucks owned by guys named Frank?
[albumimg]3517[/albumimg]
Posted: August 25, 2008, 9:11 am
i have multiples of both style heaters.
heres the deal
deluxe heaters had extra controls and a cable operated flapper inline in the hose.
standard heaters had a manual operated valve (plumbing style shutoff) on the manifold.
pm for parts if you need them.
pics of heater cores and boxes in hints and tricks
http://fordtruk.com/forums/viewtopic.php?t=4840
