Transmisson's T5
Posted: September 23, 2008, 9:24 pm
by pcbdavis
New to the forum. Looking for all the info I can get for the T5, I currently have T98, which going out and feel the T5 would be better. Not sure what I need??? The T5 from 83 to 95 T5, The adapter and S10 shifter. that's it? I couldn't find any step by step info on this, looking to start collecting the items now and do it this winter.
I see ebay has T5's.... what's the going price???
Posted: September 24, 2008, 6:36 am
by fmartin_gila
Go to www.ford-y-block.com scroll part way down. That is John Mummert's website. I used his adapter setup when I put a T5 in my 62. His setup is as close to a 'bolt-up' as you can get. I did have to "adjust" the flat floorboard slightly to get enough heigth clearance above the tranny. I just made an offset out of 1/8th inch steel to move the shift lever a little forward, rather than using the S10 components.
Fred
Posted: September 24, 2008, 6:41 am
by fmartin_gila
Forgot to mention some things. Do your research prior to buying a tranny. You need certain models of the T5 to use with different engines and bellhousing combinations. Do a search for T5 and you will find all kinds of information.
Fred
Posted: September 24, 2008, 8:24 am
First of what year truck do you have? What engine? the main difference for our use is 85-93 T-5s have a shorter input shaft and you will only want to use the 5.0 version, they require a modified bellhousing (which Mummert does). The 94-95 tranny a 3.8 or 5.0 will work, you use an adapter plate with it, has a longer input shaft but it needs cut. The S-10 tailshaft housing is correct for either to move your shifter to the stock truck location. Here is a link to an install behind a 292.
http://www.y-blocksforever.com/forums/T ... 4-4-1.aspx
Posted: September 24, 2008, 2:04 pm
by pcbdavis
62 with 292, trying to get as much info as possible. Been searching all over the web for info, want to make sure I get the right items. thanks
Posted: September 25, 2008, 10:05 am
by Truckfarmer2
Friends of mine adapted the stock bellhousing to use a T-5 behind a 223 and behind a 292 Y-block. The article is on Badgerland F100's page....
www.badgerlandf100s.com/techcorner
Posted: September 25, 2008, 4:59 pm
by pcbdavis
Posted: September 25, 2008, 9:11 pm
by Mike P
Do you think a t-5 from a 92 s-10 would work?
Posted: September 26, 2008, 8:24 am
by charliemccraney
An S10 T5 will probably have a very short 1st gear almost like a granny and it's not rated for a lot of torque. Plus adapters are not readily available to mount the Chevy pattern transmission. Try to find a Mustang V8 T5. '86 to '93 is easy to fit. Typically, the later the model, the stronger the T5. I've noticed that some places can rebuild T5's to the 330ft/lb spec of the Ford Motorsports T5. And some places can build them to support power levels close if not equal to that of a TKO. You can put the S10 tail housing on the back of a mustang case so that you don't have to mess with the seat or find a shift handle that will work.
