thermostat part 2
Posted: October 28, 2008, 7:51 pm
by willy3486
I posted a question a while back on the thermostat of my daily driver 4 banger truck. It would not get warm. So I changed the thermostat, boy thats caused problems. Now it gets to half way quickly and it will continue higher in slower driving. Before everything looked like it was ok other than the engine did not get warm before I changed it. . Well I did all the suggestions I have been told for the most part. I took the hose off the heater intake,heater out, top hose and let the air go out of each one. I even took the hose off the thermostat end and pryed the thermostat open a little to let that air out. So tonight I took the top hose off and let the air escape. I put it back on and it run fine in park, it got up to almost half way. I also watched the with the cap off and no water was flowing as far as I could tell . so I put the cap on and took it out for a spin. Well it went up to about 70 % up. I drove it back home and let it idle while I checked it. I noticed while it was hot on the gauge and the engine seemed hot, the upper hose and radiator was cold. The bottom hose was a little warm and one heater hose was hot and the other was a little cooler. I opened the cap a little and the water poured out. It was cold as I figured. So I am thinking the thermostat is not opening up much if at all. I don't think it is the water pump since it did not get hot before I changed thermostats. So Am I correct in thinking I should change the thermostat again?
Posted: October 28, 2008, 9:41 pm
by johnny
didnt want to say anything yesterday but here goes the thermostat is not upside down right? shouldnt even say it but it has happened to me ah when i was in high school ah ya thats when ya pointy side up looking at you
John
Posted: October 28, 2008, 11:22 pm
by ezernut9mm
if it's not the t-stat, the system could still need to be "burped". find a forum on the specific truck you are working on to find the proper way to get all the air out. jmho.
Posted: October 29, 2008, 6:49 am
by willy3486
As far as a specific forum for the truck I tried that. There is a site for the truck and I got a couple of responses. I tried them but I always get good advice and more here. As far as being in correct it should be. I put it in the same way it came out with the exception of the air hole to leak out I put a little lower than towards the top. It looked like it went in that way but one guy at a parts store said that shouldn't matter. I am at my witts end. I need to use this truck as long as I can and not go out and trade it due to the economy, quire simple I can't afford a car payment on what I get paid. When the economy gets going again I shouldn't have any trouble getting a job that pays a lot more. Anyway the one I got was 185 degrees so I am thinking about seeing if I can find one that runs cooler and just replacing it Friday. Start this crap all over again.
Posted: October 29, 2008, 8:10 am
by slick4x4
this is how i ''burp'' an engine
cover radiator so no air can pass thru
take off rad cap
start engine, turn heater flow control on
with the rad covered , once it warms up it should continue to flow
keep watch of coolant level & add if needed
never had any problems with this method
my
Posted: October 29, 2008, 8:37 am
by 62galxe
I like to test them before installation.put them on the stove in a pot of water with a thermometer.you can verify the opening temp this way.
by dwbr
i have allways drilled a small hole in the tstat, plus it makes draining and filling easy
________
BMW R1200GS history
Posted: October 29, 2008, 8:39 am
by BigTim
Could you have gotten a bad thermostat? I think you can test there opening temp with a pot of water, stove, and thermometer. Second hand info on that, but it might be worth a try. I'm sure others will chime in on the topic.
Posted: October 29, 2008, 2:16 pm
by Slick Fan
dwbr wrote:i have allways drilled a small hole in the tstat, plus it makes draining and filling easy
Me too. Usually a 1/8" hole.
