Rust preventive paints -
Zero Rust - Comes in qts ($25) , gals and spray cans (many colors) No need to topcoat. (but watch thier shipping- $)
http://www.zero-rust.com/
Restomotive / POR-15 - Makes a very FULL line of specialty coatings for the restorer / hobbiest. Not just rust preventive paints. Comes in pts, qts ($45) and gals. Mention the "club" for a 10% disc.
http://www.por15.com/ I put this one here a couple of years ago. POR-15 is around $45 a Qt now. (11/09) Ouch!
Rust Bullet - Comes in qts ($52) , gals.
http://www.Rustbullet.com
MasterSeries - Comes in qts ($31), gals.
http://www.masterseriesct.com/
Bill Hirsch Paints - Comes in qts($37), gals.
http://www.hirschauto.com/
Eastwood Company, Corroless Rust encapsulator. ($38)
http://eastwood.resultspage.com/search? ... ubmit.y=14
Rust preventive paints and coatings
- Customcab4x4
Last edited by Customcab4x4 on September 30, 2012, 1:43 am, edited 12 times in total.
Phil
64 F-100 (on modified 79 4x4 chassis)
63 1/2 Galaxie 390/4sp.
66 Mustang
89 F-150 Lariat XLT
66 Mustang
89 F-150 Lariat XLT
http://evapo-rust.com/
this is a product i found a while back and ive bought some of it but ive not used it.suppose to be able to dip the rust into this solution and let it sit and will do away with rust.will let you know if you want how mine turns out
Ryan
351w/Aod
351w/Aod
POR15 *Caution Pics*
Before and after POR15, brushed on...
- Customcab4x4
POR-15 finish
That stuff is amazing isn't it? It's hard to believe it flows out that way, but it sure does.
Phil
Phil
Phil
66 Mustang
89 F-150 Lariat XLT
66 Mustang
89 F-150 Lariat XLT
Man, that looks beautiful.
Cumminsturbo22
Holy chit, that was brushed on? I'm using Eastwood's right now on my frame and under the cab. It doesn't go on that smooth but it also doesn't have that gloss.
I'm doing the bed section in March, I might try the POR15 instead of the Eastwood product. I went with Eastwood because it was directly compared to POR15 and held up better.
I'm top coating with JD Blitz Black so not worried about UV protection.
1991 Porsche 964 Cabriolet
2006 Cheby Silverado
- mosquito13
Re: Rust preventive paints and coatings
por 15 is the bomb. tank sealed a motorcycle tank 6 years ago no problems with the gin in my gas. did all the galvanized parts on my flats boat trailer at the same time . leaf springs still look good where i used to replace them every 4-5 years . i got lazy on the rear floor pans of my dodge which had pin holes . used two layers of glass matt and five coats of por15 . those pans are solid and now hidden under the carpet. flows out great and now they have some high temp options...
Hot Rod Rock every Tuesday 3-5pm Eastern on http://www.wslr.org
63 f100, 64 dodge polara, 74 john player norton, lots of rd 350's & 400's,
1977 kz650 (it's a sickness...)
