Paint question
Posted: November 20, 2008, 5:44 pm
by 61ford
fixing to do my first paint job base and clear on a f350.i was told that i had to buff and wet sand do i paint the base then wetsand(was told 2800?)then lay the clear then after that buff the clear?
Posted: November 20, 2008, 6:19 pm
by Uncle Skip
As a general (and only a general) guideline.
You only need to wet sand if you have runs and "stuff" in your base coat. Otherwise, let it cure for about 6-8 hours, tak-rag the finish, then shoot your 3 or 4 coats of clear and let that cure for as long as you can stand it. Once it's cured, start with 1000 grit wet sand, and go up from there. You buff at the very last.
When in doubt, talk to your paint supplier.
AND, be very careful and make sure to wear a respirator and eye protection. Nothing is more important than your health.
Good luck.
U@ss
Posted: November 20, 2008, 6:20 pm
by Max
http://www.autobody101.com
One of our members here is the moderator there - very useful information for any paint & body questions.
Posted: November 20, 2008, 6:56 pm
by grump
If you have to sand on your base coat be sure to blow some more base coat over the area you worked on. 6- 8 hrs between base coat and clear coat sounds a little long. PPG base coat wait is about 30-40 minutes depending on how many coats, that's for DBU base coats. check the tech pages for your brand of paint. Follow the tech pages religously, paint is too expensive to screw it up.
Posted: November 20, 2008, 7:01 pm
by Uncle Skip
Grump.
Thanks for setting me straight. Our painter doesn't sand the base coat that I know of, but maybe he does.
I can't stand to watch because he's so damn good and my applications look like they were put on with a broom.
As for letting things cure for that long, remember, we're here in Houston and even in a heated booth, Jeff says its better to wait a little longer than to do it to soon.
By all means, follow the directions to the letter and ask a professional if you don't understand the tech bulletins.
U@ss
Posted: November 20, 2008, 8:07 pm
by 61ford
who is the adminster you all know i registered for that site bout a month ago but never got an email to get my account active.Also whats the thinking behind the eye part? i did go out an get a paint suit and im also wearing a respirator
Posted: November 20, 2008, 10:00 pm
by Demonknight
going on a limb here as I haven't read that site, but I have done a bit of painting years ago..even with 5 exhaust fans the fumes/tiny paint drops would coat up our safety glasses in about a week to the point we would just toss them out. all that crud in your eyes can't be good for them.
