Brake Light Bracket ( pattern ) conversion for 1965
Posted: November 23, 2008, 4:14 pm
by jhewitt
I had copied a pattern from one of these sites a fellow had done, the pattern when fabricated allowed the brakelight switch to locate under the dash and ride on the brake pedal lever, the dims on his patterm was in MM and when converted out doesn't seem right, and doesn't match the printed form, does anyone have the actual dims and pattern in U.S. regular inches?
Posted: November 23, 2008, 5:16 pm
guess you are talking about this
http://fordtruk.com/index61.html
i have no idea why Lance did metrics on that piece,
i just took the rubber bumper out and put my switch in the existing hole.
Brake Light Conversion
Posted: November 23, 2008, 6:05 pm
by jhewitt
YES
Thats it
Thanks the print out of the pattern ISN'T the measurements, you think he has the US measurements?
You say you just removed the rubber bumper and the switch fitted in the hole and works ok?
Posted: November 23, 2008, 6:24 pm
yes. i put a nut on both sides to keep it in the correct spot. ill see if i have a pic.
