extra dark last night
Posted: December 23, 2008, 1:20 pm
just sat down for my evening look at the forum when out went the lights. dont know what the cause was , driver related or tree fall but it was 6 hours before it came back on.
i think there should be some upgrades
1.all power lines should be put underground if possible
2.all trees within striking distance of wires should be cut down.i cant imagine how much $ has been wasted cutting and removing trees from the power lines after they fall on them when its much easier before.
this would end most of the power outages.
6 non-electric hours is not a big deal, having lived several years without any but several days or a week for those who have never been without has to be hard.
Posted: December 23, 2008, 1:33 pm
by DCarr
Around here fallen trees on power lines also cause billions in fire losses. :(
Posted: December 23, 2008, 1:41 pm
by Lowell
Hey Ice
Went thru that in September for almost 4 days when wind from hurricane Ike came through. It brought down a lot of trees and big limbs. I was on the verge of taking all the stuff from my freezer and taking it to my moms and some friends when they finally got the power back up . Luckily i had a travel trailer so i put a lot of food in the rv fridge. Bought a generator since then, but may not need it for ten years. but at least im more prepared for whatever. I had removed some trees close to the house in april so didnt have to worry about damage from them.
Lowell
Posted: December 23, 2008, 1:56 pm
by slick4x4
''.all power lines should be put underground if possible''
i disagree with this... as a rural water district operator, somebody digging would get killed, as often as our lines get ''accidently cut'' i know it is bound to happen
''all trees within striking distance of wires should be cut down.i cant imagine how much $ has been wasted cutting and removing trees from the power lines after they fall on them when its much easier before.''
i agree with this... last year when we had an ice storm, the trees pulled the power lines down... yet some homeowners would NOT let the power companys trim them back very far ( dumb , stubborn )
Posted: December 23, 2008, 2:02 pm
i do agree there are problems with diggers but there is a free locating sevice for underground lines and pipes that can and should be used
Posted: December 23, 2008, 2:04 pm
by 36truck
Key word is should be used not all do.
Posted: December 23, 2008, 2:16 pm
by Fordman
thier are gas water and power services. and only two sides of the street. putting gas on one side and water on the other side is good. when youput stuff underground a person should be smart enough to put the stuff far enough apart that it can't be hit when digging. i forgot about cable and phone lines. oh and dig safe should be used for sure.
Posted: December 23, 2008, 2:24 pm
by Slick Fan
Our power lines are all underground...we still have power losses. Mostly in the summertime though, from too many a/c units cranking at the same time. :lol:
Posted: December 23, 2008, 5:04 pm
by Alan Mclennan
There`s no big problem when digging around power conduits, as long as they were installed correctly, with sand around them and warning tape above. we have both above and below, depending on the age of the area. We also have a free service called Dial Before you Dig!, and they will supply you with plans of where their services are, basically going from the kerb, directly below the kerb is the storm water main, then at 750m is the water main,then in some cases recycled water, then electricity at 1.5m then telephone/ coax and cable TV, natural gas is about 500ml from property boundary. The fun part is trying to run a 375mm storm water drain across all of them at a depth that can not be changed. under ground is best far less poles for cars to hit!
Posted: December 23, 2008, 8:38 pm
by semotrucker
OOPS...We wouldnt want to mention the cost of cutting Southwestern Bells MAIN cable that handles calls from way down in Texas all the way up to the Chicagoland area...my ex boss knows just how expensive that is...the frostbite(cutting blade) on my 14 yard reynolds dirt scoop cut it right in two out in the middle of a field down here in semo. LMFAO...aint thought about that in years.
Cam
