'96 F-150 4x4 question
Posted: January 12, 2009, 10:44 am
by The Big M
My dad's F-150 was involved in a collision this past week vs. a small suv. No injuries, but it looks like the F-150 is a write-off due to some frame damage. It's a nice truck, fairly low mileage, good body, new tires, and some suspension and engine upgrades (load-leveling air bags, Warn hubs, throttle body spacer, etc.).
The question is this: In the event that the frame damage can't be repaired, is it possible to replace the entire frame with one from a 2wd F-150 and swap over all the suspension and drivetrain components? If so, which years will interchange? Or is a 4x4 frame of that year significantly different from a 2wd frame?
The truck has a 5.0 and AOD-E and it's a regular cab longbed. I'm told the damage is to the driver's side front framerail, but I haven't seen it myself so I can't comment on the extent of it, unfortunately.
I did a search over at that "other" site, but was hoping someone here would have some insight. ;) Just wondering if this is a bolt-on affair. Thanks.
Posted: January 12, 2009, 11:03 am
by 36truck
2wd &4wd frames are different that's why you need a rear sump oil pan on a 4x4. Find out how bad the frame is might be able to straighten it on a frame machine.
The "is it repairable" simply comes down to $, is it worth enough money vs repair cost (you are likely dealing with an ins co that only sees it in dollars). You should have seen the frame on my 94 E cab 4x4 before they fixed it. :shock:
It may be less work to find a nice truck with a bad driveline and just swap the engine & tranny. It really comes down to what you are willing/can afford to do.
I believe the rails are the same (except the Lightning) but the front crossmember is different, you probably don't want to try to swap that.
Posted: January 12, 2009, 11:22 am
by The Big M
I'm told the damage estimate is around $5000. It's in Saskatchewan where there's only one insurance company (Saskatchewan Government Insurance, publicly-owned). It definitely only sees the bottom line. That cost includes their estimate on parts and labour to repair the other damage (grille, fender, headlight, radiator) so it may be possible for him to just have the frame repaired and replace the other parts himself for less.
I don't think crossmember replacement is an option unless it bolts in. If it's welded in then frame repair would be a much better option. It all depends on what their buy-back cost is too.
As for the donor cost, local 2wd pickups can be had for under $500 but 4x4's are up near the $1500 range. Which is why the idea of using a 2wd frame came up. And my dad's truck is really clean for its age, so I think the body is worth saving. I think it'd be tough for him to find a comparable truck with a bad drivetrain.
Posted: January 12, 2009, 11:27 am
by 36truck
That is key as to how much it cost to even get the truck. If you do all the work but the frame straightening it might not be to $$$.
Posted: January 12, 2009, 11:36 am
by The Big M
He's still waiting to find out what the buy-back is. If it's around the $1000 mark then it's probably worth getting back just for the new tires.
A part-out may even be the best option. It sucks, because now my dad has no way to tow his boat!
Posted: January 12, 2009, 12:15 pm
by DCarr
He can always buy a slick. :)
Posted: January 12, 2009, 12:45 pm
by The Big M
Maybe I'll suggest that. He did have a '64 once. :)
I found this, which suggests that the swap is bolt-on:
http://www.ford-trucks.com/article/idx/ ... 0150s.html
Can anyone confirm?
Posted: January 12, 2009, 12:59 pm
by 36truck
I forgot about this post. Greg switched over his 2wd to 4wd.
http://www.torinocobra.com/forum/viewto ... highlight=
Posted: January 12, 2009, 1:17 pm
by The Big M
This would be a bit different. That's an F-350 with leaf springs. The F-150 has coils. What I'm suggesting would be a conversion from a coil-sprung twin I-beam 2wd front end to a coil-sprung 4x4 twin traction beam (ttb) front end.
Edit: Also found this link: http://www.fordf150.net/forums/viewtopi ... sc&start=0
This makes me think that the crossmember difference between 2wd and 4wd only exists in the 73-79 trucks, not the 80-96. So far it's looking like a bolt-on project, albeit a time-consuming one.
