Garbz Maniacial in the closet Building of a 63 Ford truck
Garbz
Post by Garbz »
See i cant get away from it...
Will drop in pics and tech as i can from my Photo bucket and archives...
Garbz
Garbz
Grill Mods
Post by Garbz »
Modified the grill to delete the turn signals. I will use Lucas type headlights with built in TS.
<a href="http://s368.photobucket.com/albums/oo12 ... 200074.jpg" target="_blank"><img src="http://i368.photobucket.com/albums/oo12 ... 200074.jpg" border="0" alt="New Grille As modified" ></a>
<a href="http://s368.photobucket.com/albums/oo12 ... 200071.jpg" target="_blank"><img src="http://i368.photobucket.com/albums/oo12 ... 200071.jpg" border="0" alt="New custom Grille" ></a>
Garbz
Garbz
Grill Mods
Post by Garbz »
Just one of the many things happening
Garbz
ezernut9mm
Sweden
Post by ezernut9mm »
great build garbz. can't wait to see the finished product. it will 180* out of what i'm doing for sure. i hope to bring my whole project in for less than 1500 and minimal labor. lol. yeah, right.
Garbz
Post by Garbz »
Ezer. at this time i have less than 2K in the entire build. And that includes the truck it self.
I am doing it with all my labor so saving that cost.
ezernut9mm
Sweden
ok. we are on par $ wise, but we are definately 180 out in the skills department. lol.
Anthony
Post by Anthony »
don't you think that the grill resembles a 67-69 grill after you took the turn signals out???? I like it Garbz....keep up the good work :thumright: Anthony
blackagatha
Post by blackagatha »
I might do that to mine, if the right end wasnt mangled. I need to replace the grille and upper and lower valances. They are all tweaked out from when She lost the front right wheel in a previous life.
Roger Carter
Post by Roger Carter »
I like the grill mods. Have to agree with Anthony, it does look like a later Bump grille.
I envy your metal working abilities. Appreciate the pictures.
Roger
Garbz
Post by Garbz »
The front suspension installed. still have the stock spindles on it. Plan to add the 2" drops in the next month.
Passenger side
Steering shaft and setup
Heres a closeup of the steering shaft, U joint and collar.
More to come. I hope to have it a roller by the end of the month.
Garbz
ezernut9mm
Sweden
progress is good!
:shock: Garbz, is that rust I can see?, I thought you were building it in Arizona! :lol: :lol: , just pulling your leg!, that looks real good she will sit quite low by the look of it!, more pic`s please!
Garbz
Post by Garbz »
It does rain here......
I am putting it all together. Make it all work correctly then pull it all back apart for detail and paint.
Garbz
I noticed we both have rubber mallets in our pic`s, If in doubt give it a clout, the bigger the doubt the bigger the clout! :lol:
DCarr
Post by DCarr »
Nice job , Garbz. Did you fab the intermediate shaft?Thanks, David.
Garbz
Post by Garbz »
Yep if it don't fit force it. That is my Motto Alan..
Dave the shaft in the column is a cut off from a 61 to 64 ford box with a double D machined on the end. The collar to hold the column together is a piece of .125 3/4" ID tubing with 2 tabs welded to it with a cross bolt. Holds everything together nice and will allow me to run a stock 17" slick steering wheel.
The lower is a Flaming River Double D S/S that is a slide in fairly tight fit to the stock double D vibration joint at the bottom. It is in there about three inches. allows a bit of slip as the body and frame flex.
Garbz
johnny
Post by johnny »
did you z notch the frame of is that kick up stock if i do it again id do dakota youve sold me wish i new 4 years ago very nice it will be done for the western nats right dave ya ya ya
John
2) 55 f100's
2) 65 f100's
and all the other ford trucks my wife doesn't know about!!
Garbz
Post by Garbz »
Johnny I am shooting to have it there.
Yes i placed a 2" Z notch in the front frame to slam it down lower.
I may be just as you see it in all patina and rust. I want to assemble everything get it going then blow it apart for powder and paint.
I figure i can do that in the next four months. Just need to watch the budget.
Garbz
twistedfreak
Post by twistedfreak »
looks sweet man keep it up
""WE THE WILLING, LED BY THE UNKNOWING, ARE DOING THE IMPOSSIBLE FOR THE UNGRATEFUL""
Shawn F.
Post by Shawn F. »
Garbz, the truck looks great! I will have to pick your brain here on the Dodge Dakota front end. I am going to ditch my entire Dropped I Beams, front disk brakes, etc and go with this with the fullsize hubs, etc to run 5x5.5. Only thing I need to figure out is the brake booster, steering, etc. With that steering setup like that, will my 351W fit with my 5.0 foxbody mustang headers? It took me a long time to find headers that fit in my truck and I have to backorder them which took forever and finally got something that looked great, functioned nicely and fit, I'd hate to go through the same thing again if they will not fit...
What did you weld the front end up with and where did you get the parts to rebuilt the ball joints, tie rods, bushings, etc?
Thanks for any info at all on this and tips!
