rust help
Posted: February 1, 2009, 6:06 pm
by 62galxe
on the inside of my hood under the bracing on the front is rusty. any ideas on how to kill it short of cutting the hood in half.
thanks kenny
Posted: February 1, 2009, 8:47 pm
by clevor347
I had good results with this, was about 8 bucks. A friend has a 76 trans am with the rust on the hood pitted through the metal completely to the point where it had pin holes you could see through. He used a product called ospho which can be found at any automotive place. It worked really good too.
Re: rust help
Posted: February 2, 2009, 2:17 am
by BackyardRest
62galxe wrote:on the inside of my hood under the bracing on the front is rusty. any ideas on how to kill it short of cutting the hood in half.
thanks kenny
post a pic of problem area
Posted: February 2, 2009, 12:48 pm
by 65Lover
Kenny
I have the same problem with the hood I got off of Ebay, except it's the front and back bracing. Lucky I got it for cheap! It's better than the hood the '65 came with and the hoods aren't reproduced so I may just spend the money and have it done right. I don't want the rust coming back in the future!
The body shop said to do it RIGHT they need to cut the bracing out, blast and treat the inside rusted areas on the bracing, weld the bracing back in and finish the hood. Around $800 with some other repairs to the hood(fix 2 dents, fill in trim holes).
Second option was to cut access holes to the inside of the bracing, spray rust stopper/converter as best they could and weld up the holes, this would bring the price down to around $500-$600.
Let us know what you end up doing please. My hood fix decision is in the very near future!
Posted: February 2, 2009, 7:32 pm
by FORDBOYpete
Kenny,
IMHO. . .
If you can't replace the hood, or replace the metal part that's rusted out, your 3rd alternative
is Ospho Because the Ospho is basically a phosphoric acid formula which converts corrosion
into an oxygen impervious barrier helping to prevent further degeneration by rusting.
We use it restoring aircraft, USN uses a similar formula & Oil Rig guys use it on Ocean rigs.
Of course you have to seal it after you have applied it. Prep & coat it with a good anti corrosive paint.
FBp :thumright:
Posted: February 2, 2009, 7:54 pm
by 62galxe
its not rusted through but the area above the bracing is rusty. it is inaccessible without removing the bracing. the hood latch is attatched to this brace. maybe stand the hood on its nose and pour something in there and slosh it around. i have spotweld cutters and welders but was looking for the easy way out. ill have to see how hard it is to remove.
