Refresher Course
Refresher Course
On an FE, with #1 at TDC, the business end of the rotor should be pointing roughly towards the carb area and the timing marks should be lined up on the sprockets? I'd like scratch a mark for reference before I take the dist and manifold off tonight for cleaning, but left my book at work.
What's in the garage at any given moment?
FE powered Bump
93 Lightning
66 Slick strewn all over the place
08 Taurus
13" Huffy W/ training wheels
FE powered Bump
93 Lightning
08 Taurus
blackagatha
hmmm. On mine, the #1 is approx 1 oclock
But the vac is in the viciniy of 5 Oclock...
Or you could just do what I did when I pulled it apart for my mods this xmas.... I scratched the dizzy rim where the rotor was pointed, and marked it again after I pulled it, and it rotated as the gears disengaged.
SO when it came time to stab it back in, I just lined up the mark and dropped it in
(this will only work if you dont spin the crank while it is out.) and it gets hard if you find the need to prime the oil pump, as it leaves the oil drive out of its alignment.
Technically, your rotor doesn't care where it's pointing. With #1 piston at TDC & no plug wires attached to the cap, you can drop your distributor in wherever it's comfortable, then pop your cap off & stick your #1 plug wire in at whichever terminal the rotor is currently pointing to.
From there, you just plug each wire on, according to the firing order.
The only real reason a person would want to have the rotor pointing at a certain cap terminal, is if you don't want to have to re-do your plug wire routing...you're comfortable with the way the wires are currently routed to the distributor & don't wanna mess it up.
it does not technically matter as long as the firing order is correct and #1 fires at the proper time but its also nice to keep it in the original spot so the plug wires are correct on the cap when you put it back on.15426378 in a ccw rotation.
Thanks guys! It's all coming back to me now. I would like to keep everything in the origional spot so there is one less thing I have to remember, or forget, in the future.
FE powered Bump
93 Lightning
08 Taurus
FE powered Bump
93 Lightning
08 Taurus
blackagatha
