Transport Question
Posted: February 17, 2009, 8:25 pm
by cookster4495
Thinking of dragging home a 1 ton dually from kansas.Todays car dollys are rated for 35-3600 lbs,would this be a safe move? Have a 1 ton dually so tow unit is no problem. If it was a short hop I wouldnt be asking,but almost 1200 mi lots could go wrong. Larry
Posted: February 17, 2009, 8:40 pm
by jwh f-100
Larry, I'd say, as you mentioned, your tow rig is got what you need, big brakes and power. As far as the dolly handling the weight just think about all the 1/2 ton pickups with passenger rated tires flying up and down the highways with heavy snow plow hanging off the front. I would think the dolly's tires/bearings/spindles ect. would be just as heavy or heavier than a pick-up axle.
I'd think you would be fine with no "slamin & jamin". I would worry more about the rear tires and axle holding up.
Any bites on the chassis??????
Posted: February 17, 2009, 9:13 pm
by 36truck
Is the tow dolly wide enough to hold a dually on. I think you might be pushing it with a dolly.
Posted: February 18, 2009, 3:04 am
by blackagatha
one of those little crappy Uhaul dollies with the little bitty tires? OH BOY... I dunno dude... Can you say PRE TRIP INSPECTION???
And, You might want to consider the Legal Rated Load on the thing too. If the Cops decide that you have it dangerously overloaded, you might find a bit of trouble....
I would earnestly look into it, and Not try to do it "sneaky".
