Page 1 of 2
110 plasma cutter..
Posted: March 11, 2009, 4:35 pm
by jwh f-100
Me want!!!
Thoughts????
Once you use one you can't funtion without, atleast I keep telling myself that.. We have one at work, "me want" one at home...
Maybe I can continue to get by with the sawzall.....
Posted: March 11, 2009, 5:17 pm
by 61 Merc
Yeh, I want one too, but then again would I be better off with a good compressor, a torch set or putting the money into the slick.
I think I will stick to putting it into the slick at this time.
Dean
Posted: March 11, 2009, 11:18 pm
by frank66
My father has one. We don't use it that much. Its usually easier to use a sawzall, jig saw or oxy acetylene.
Posted: March 12, 2009, 12:37 am
by blackagatha
frank66 wrote:My father has one. We don't use it that much. Its usually easier to use a sawzall, jig saw or oxy acetylene.
on what basis?
Everything Ive seen looks like butter.... Dont have to worry about ragged cuts from torch, entry points for saw, curves no problem.
Dont have to worry about using it up either, do you? no gas to buy, blades to get dull.... Nor vibrate you to death as with the sawzall...
Posted: March 12, 2009, 6:54 am
by jwh f-100
61 Merc wrote:Yeh, I want one too, but then again would I be better off with a good compressor, a torch set or putting the money into the slick.
Dean
Very good point Dean, I could easy spend the money on something more valuable to my project. I do need a new compressor, mine is junk.
BA, Actually with a steady hand and a good tip on the torches you can make a pretty nice cut with it. Would it compare to a saw or a plasma, no but not bad.
Posted: March 12, 2009, 1:10 pm
by Slick Fan
I saw an ad recently in our local online classifieds here, of a guy selling one that was mounted to a jig of some sort. It looked like it would make some super clean cuts...but like you guys have said, I have other things to spend that money on.
Posted: March 12, 2009, 1:30 pm
friend of mine has a bigger plasma cutter no point in me spending the $ as i can go visit , b.s. for a while and get whatever cut necessary.
Posted: March 12, 2009, 2:25 pm
by Gritsngumbo
I''ve had my eye on a small inexpensive one for a while as well as a "soda" blaster from Eastwood's. Either one is going to require a compressor upgrade as my little one doesn't have the CFM to meet their requirements. So I guess the compressor comes first (which will require an electrical upgrade to 220). If it ain't one thing it's another.
Posted: March 12, 2009, 4:46 pm
by frank66
blackagatha wrote:frank66 wrote:My father has one. We don't use it that much. Its usually easier to use a sawzall, jig saw or oxy acetylene.
on what basis?
You do have to replace parts in the gun, electrodes and what not.
I do my fair share of fabricating and rarely use it. The one we have will only cut metal 1/8" thick.
http://i363.photobucket.com/albums/oo75 ... 260484.jpg
http://i363.photobucket.com/albums/oo75 ... -08027.jpg
http://i363.photobucket.com/albums/oo75 ... CF0686.jpg
Posted: March 12, 2009, 5:11 pm
by 36truck
I'm a sawzall & torch kind of guy. I think that is because before plasma that's all there was. Old school you know.
Posted: March 12, 2009, 5:29 pm
by Gritsngumbo
Jason: Which unit are you considering? How much?
Posted: March 12, 2009, 6:29 pm
by jwh f-100
Gritsngumbo wrote:Jason: Which unit are you considering? How much?
Gerald, I was kinda thinking I'd like to have a 110 volt unit with a built in compressor.
http://www.northerntool.com/webapp/wcs/ ... _200336604
But the more I think about it, like the guys mentioned, there is probably better ways to invest in my shop. The other thing is that today I checked the one at work and it has A standard 220 plug. I was thinking it was a different plug.
I can run the cord from the garage into the mud room and use the dryer plug...
Posted: March 12, 2009, 7:37 pm
by DCarr
Yeah ,Jason -I can't see a 110 plasma being able to do much except thin
sheet metal. Probably better to get a large air compressor first.
Posted: March 12, 2009, 8:15 pm
by 36truck
Fact an air compressor is way more useful than a plasma cutter.
Posted: March 12, 2009, 9:14 pm
by Gritsngumbo
Quote: I can run the cord from the garage into the mud room and use the dryer plug...
I had actually considered getting a 220 extension cord and run it from my studio, but for $100 I can probably get my garage upgraded to 220.
Posted: March 14, 2009, 4:34 pm
by 61ford
if you want a plasma dont cheap out i started out with a harbor freight after 3 returns within yr half most lasted bout 6 months i got a hypertherm.absolutely best investment ever no more cut it short or long or having wavy cuts with a stupid sawzaw shouldve bought it when i started on mine.you do have to replace the tips and it saves so much time.
Posted: March 14, 2009, 7:28 pm
by Gritsngumbo
61ford wrote:if you want a plasma dont cheap out i started out with a harbor freight after 3 returns within yr half most lasted bout 6 months i got a hypertherm.absolutely best investment ever no more cut it short or long or having wavy cuts with a stupid sawzaw shouldve bought it when i started on mine.you do have to replace the tips and it saves so much time.
Price range for the Hypertherm at the low end?
Posted: March 15, 2009, 12:34 am
by 61 Merc
For the price of a cheap plasma cutter I could buy a new 18.5 CFM compressor, wire the garage and buy a complete torch set with bottles. I think I know where my money is better spent. I have also seen some of the work of the plasma, a torch could do just as good, and better on thicker metals.
Dean
Posted: March 15, 2009, 3:39 am
by blackagatha
I guess we need to get the correct torch tips.... Most of what we cut out looks like hell.
We have traditionally been running WAY too much pressure as per my grandpa's incorrect advice. According to a website we found, the acetylene pressure he had us running can supposedly cause the bottle to blow...
when we turned down the pressure it acted better. I think the tip is probably still too big. Makes gross bubbly slag all over the cut.
It sucks how quick the bottles go empty.... I would rather replace the electrodes and run the compressor. But, the Plasmas are crazy expensive.... and REALLY lots if you get one good for the same thickness of metal that a torch can cut...
Ive been considering experimenting with an electrode and air nozzle clamped in the arc welder stinger.... Fashion up a homemade cutter....
Posted: March 15, 2009, 6:58 am
by 61ford
ah you can get one that will only cut 3/8 for like i think somewhere bout thousand mine cuts up to 1/2 and i gave 1500 for mine.i would only buy a hypertherm when it comes to a plasma a lincoln and a miller are just rebagged there not actually made by themselves hypertherm i was told was the company to come up with the plasma cutter and i believe its all they make ive been very impressed with mine
