Page 1 of 2
Bought a dent side yesterday.
Posted: March 22, 2009, 11:24 am
by jacobd
It is a beauty. Very very clean.
I need to get all the gauges repaired. Is this something any repair shop can do, or am I looking for a specialist? I'd like to make this a real nice daily driving utilitarian truck. If custom dash and gauges are out there and more reliable that would be fine. Can you steer me in the right direction.
Also any recommendations for a new carburetor. This one seems to need some attention.
Posted: March 22, 2009, 11:31 am
Sounds good, what carb do you have now?
Posted: March 22, 2009, 11:34 am
Jake,
might be a fuse or the instrument voltage regulator that is the gauge problem. you can check on that yourself.
other could be bad sending units.
cant remember what engine you said it had - 460? or if its 2 or 4v carb.
Posted: March 22, 2009, 11:45 am
by jacobd
I had to have the alternator and regulator replaced at a shop before making it home. I learned it is a 460 with a 4 barrel carburetor.
Brian you would need to tell me where and what to look for.
I noticed when turning the headlamps on that the flicker with the movement of the alternator gauge.
The gauges that work are the speedoometer and maybe the alternator. Is it supposed to sweep back and forth rapidly?
Oh one more thing. The mechanic said I needed to add transmission fluid.
He said Merc V. The people at pepboys said type F. I went with the Merc V. Is there cause for alarm?
Posted: March 22, 2009, 12:31 pm
The later "mercon" fluids have a component in them to "soften" shifts. All trannys new enough use them.
In the old days we used to run Type F in GM trannys to firm the shifts up (BTW not good for the trannys). I have also heard that the Mercon V is OK for about anything but don't take my word on that. If I were you I would do a full fluid & filter replacement on it for no other reason as then you will know when it was done last. Most auto trannys should have a service interval about 25 - 30,000 miles. It's one piece of maintenance alot of people never think of.
I'd say on the carb either rebuild it or buy a replacement if you prefer.
Posted: March 22, 2009, 2:28 pm
by jacobd
Would you guyslook at me like this :shock: :? if I bought this for the dent?
http://store.summitracing.com/partdetai ... 52&FROM=MG
Posted: March 22, 2009, 2:37 pm
You may consider going a little bigger feeding a 460, 650 - 700 CFM?
Posted: March 22, 2009, 2:43 pm
by jacobd
Greg D wrote:You may consider going a little bigger feeding a 460, 650 - 700 CFM?
Thanks Greg. Are they universal for the most part? I ask because that is what was returned when I plugged in the search information at summit. I'll check again though. I'll go for the 700 if I can find one that fits.
Posted: March 22, 2009, 2:53 pm
I believe all square bore Holleys have the same flange aside from the Dominator based carbs. They used to anyway. One thing you might also check, make sure the bores in the intake or spacer will allow the butterflies to open, they should be a little bigger than the bore size of the carb.
Posted: March 22, 2009, 2:55 pm
by jacobd
Will this one work with my truck?
It says it isn't emission legal. Is that okay since the vehicle is smog exempt? Or, if you have a better recommendation...
http://store.summitracing.com/partdetai ... toview=sku
Posted: March 22, 2009, 3:05 pm
by 36truck
That will be more than enough carb for your truck. I just had a 460 on the dyno that mad 510 lb/ft of torque @ 2800rpm & 375hp @4500rpm with a 650 Holley.
Posted: March 22, 2009, 3:12 pm
by Fanatic
Double check that the one you choose has the Ford kickdown linkage for the trans.
Tim
Posted: March 22, 2009, 5:08 pm
by Slick Fan
If that 460 has a 4300 or 4350 Motorcraft carb on it, like this one on my Stinkin' Lincoln...
...then it has a funky manifold. It's a squarebore bolt pattern, with spreadbore bores, like this.
You will either need to buy a Ford spreadbore version of Holley (or whatever), or get an adapter like this from Transdapt to take the place of the EGR plate.
Then you can bolt a squarebore carb onto it.
Posted: March 22, 2009, 7:57 pm
by jacobd
I am ready to get the street avenger carb but I am stuck on the non emmision legal thing. Does that just apply to cars that are not smog exempt?
Posted: March 22, 2009, 9:31 pm
by DCarr
You are correct Jacob. If you are smog exempt the carb is OK.
Posted: March 23, 2009, 8:50 am
I am surprised this thread has gotten this far without someone saying this;
We want pics!
Posted: March 23, 2009, 9:48 am
by jacobd
KK I'll put pichures afer skool. 8)
Posted: March 23, 2009, 12:10 pm
by jacobd
Here is a pic I have on my desktop. I'll get a good barrage of 'em later.
Jake
Posted: March 23, 2009, 12:15 pm
by 36truck
That a 75/76? Looks good. :D
Posted: March 23, 2009, 12:23 pm
by jacobd
'75 Camper Special Ranger XLT
