Oh boy, here we go again.
Posted: March 25, 2009, 10:13 pm
by jacobd
So I'm fooling around underneath the dent with the LMC catalogue blow up sheets. See, I was trying to do some learning and such. So I'm sheckin everything out and poking at this and prodding at that. Well, right about this time I get the cleaning bug and start to wiping off some grit and grime. Pah! I learned my lesson. Won't be doing that anymore. That there grime was what was plugging up the hole in the side tank. Yeah, I know, better now than later. So I spent the better part of the evening filling up gas cans and plastic jugs with fuel.
I guess tomorrow I'll be shopping for a new tank. I'm figuring if I can take the bad one off, the new one will go on the same way.
Being that I'm so wet behind the ears any advise or upgrades or things I may want to take into consideration while I'm replacing all these goodies.
I'm thinking new pumps, sending units, fuel lines and filters.
What am I missing?
Jake
Posted: March 25, 2009, 11:37 pm
by 36truck
Wouldn't need a fuel pump as it is on the engine. Is the fuel gauge working now? if so you don't need to replace. Get the sock filter that goes on the end of the sending unit. Ford still carries it. Get new gas tank straps to hold it on unless there are in real good shape.
Posted: March 26, 2009, 5:42 am
by 66fordtrucknut
New fuel fill hoses, you'll be happy you did. So you have 2 tanks? My solenoid went bad on mine too.
Charlie
Posted: March 26, 2009, 10:08 am
by jacobd
36truck wrote:Wouldn't need a fuel pump as it is on the engine. Is the fuel gauge working now? if so you don't need to replace. Get the sock filter that goes on the end of the sending unit. Ford still carries it. Get new gas tank straps to hold it on unless there are in real good shape.
The fuel gauge isn't working. What is the piece that needs to be replaced for that?
This sending unit sock filter is something I can order from the dealership parts desk?
Jacob
Posted: March 26, 2009, 10:14 am
by jacobd
66fordtrucknut wrote:New fuel fill hoses, you'll be happy you did. So you have 2 tanks? My solenoid went bad on mine too.
Charlie
Yes, I have the two tanks. Both are 19 gallon. I did see where I could get a 35 gallon tank for the aft. Maybe a future upgrade.
I don't know what a solenoid really is yet. Will you please explain?
Thanks Charlie
Jake
Posted: March 26, 2009, 11:14 am
by 36truck
Does the fuel gauge work on either tank? If not check wires & the gauge itself. If only not work on that tank then the sending unit is bad.
Yes the filter sock on the end of the sending unit is still available from Ford.
Posted: March 26, 2009, 11:29 am
think you said none of the gauges work,tells me the instrument voltage regulator may be bad.
Grocery List
Posted: March 26, 2009, 11:32 am
by jacobd
I'm going off this list:
I will order:
1. Tank
4. Sending Unit
7. Hose gas tank connection
8.+9. Clamps
I'm unclear if I need 2 and 3 or only one of them. (please advise)
Do I need 6?
Do I need 10? It says it is 77-79 and Im 75.
No tank straps are listed. Will the ones for the aft tank work?
Thanks guys.
Posted: March 26, 2009, 11:41 am
by DCarr
Jacob, sorry I'm not much help on dents.But call or pm Tom at Flashback F100s (61-66 junkyard dog),
& tell him you are a member here. He is most helpfull & may have some good used parts to save you some money.
He is also very knowledgeable (sic ?) on Ford trucks and what you may need.
Posted: March 26, 2009, 12:07 pm
by 36truck
Your hose clamps should be fine unless you look at them & they are all rusted up.
Brian is most likely right on needing the instrument voltage regulator if the other gauges are acting up. The instrument voltage regulator is located behind the gauge cluster.
X2 on 61-66 junkyard dog knowing about these trucks.
Posted: March 26, 2009, 5:04 pm
by 66fordtrucknut
Jacob the solenoid switches the tanks it''s on the frame rail, fwd of the midship tank. you'll se where the fuel lines come into it. Tom has everything I bought my stuff from him. That midship tank comes down alot easier than it goes back up, at least with no help that is.
Charlie
Posted: March 26, 2009, 11:25 pm
by Fordman
that larger aft tank will require larger strap sto hold it in if you try and upgrade it later. i am not sure the straps are available aftermarket or not. i didn't look in my dent book.
Posted: March 27, 2009, 9:38 am
by jacobd
Fordman wrote:that larger aft tank will require larger strap sto hold it in if you try and upgrade it later. i am not sure the straps are available aftermarket or not. i didn't look in my dent book.
Good to know. From the looks of things dropping the midship tank yesterday after skool the straps could prolly be fabricated ifn I knew how to do that sorta thing.
