Throttle cable
- mcarlson11
Throttle cable
I have a 65 with a 352, and the throttle cable snapped today as I was about to leave for work. I need a new one, but I dont know where to get an original style cable from. Any Ideas?
65 F250 Custom cab, camper special. 352,4spd floor shift, dana 60 posi lock, power disc brakes in front, power steering, and fun to drive.
- DV65CustomCab
That is a very nice looking engine.
- mcarlson11
- 6166 Junkyard Dog
This cable has been disc. so good luck on hunting
Kathy
Now Cooper will try his best
I had the same problem and found an original but had a problem with it (can't remember what). What I did was just buy the Locar braided throttle cable. Easy to install and if it ever has problems then I will just send it back to them or get a new part for it. You don't have to get braided for it, they make plain black which is just fine.
Rare Parts
As a new Slick owner are there any parts that are in danger of becoming extinct that you guys know of that are good to get now while you can find them? Or are most parts readily available?
- mcarlson11
That is what i did. I ordered a lokar braided cable, will install it tomarrow when I get it.Shawn F. wrote:I had the same problem and found an original but had a problem with it (can't remember what). What I did was just buy the Locar braided throttle cable. Easy to install and if it ever has problems then I will just send it back to them or get a new part for it. You don't have to get braided for it, they make plain black which is just fine.
Re: Rare Parts
It depends on the part. For example, body parts are becoming more readily available now, than they have been in 20 years. A lot of interior pieces too.huskilvr wrote:As a new Slick owner are there any parts that are in danger of becoming extinct that you guys know of that are good to get now while you can find them? Or are most parts readily available?
Some stuff that's been discontinued by Ford hasn't been taken up by the aftermarket because of demand or cost, or both.
But it's still easier to get parts for these trucks than it is for something like a 65 Lincoln, for example.
For the braided local cable the only thing that will not work with it is hooking it up to the pedal. The reason why is because it's like a ball and socket setup and the Lokar is not. All you do is drill or hit the rivet out on the gas pedal lever up top and that hole that the rivet was in is big enough for the pin in the Lokar cable to fit it. The Lokar setup at the gas pedal has a U like thing and to close that U up the top or middle has a pin going through it... You will see what I mean when you get it in. Simple though and the braided looks nice as well, especially if you have braided hoses.
- mcarlson11
Got the cable all installed today. Didn't have any problems at all. I should have did this 2 years ago, it is so smooth! And it looks killer in my engine bay to.
