63 unibody
dragginwagon
Re: 63 unibody
Post by dragginwagon »
anything that i'll have to ground will be a nut n bolt and i'll clean the metal on the inside of the wall. only things that will be mounted on the wall should be the ignition ballast resistor and the coil....i think :)
the mount up front is like stock, but i plated the front and back of it and then cut a opening in it for a wrench to fit in. now the bolt goes in from the bottom and the nut is on the inside of the mount ( page 10 has a pic of the new mounts)
Re: 63 unibody
Post by rickairmedic »
Ok I have to ask what did you use for seam sealer around the bottom of the bbw addition to the cab ? I ask this as I will be doing the same thing to my uni and yours turned out nice and smooth which is what I want when I get mine to that point .
dragginwagon
Re: 63 unibody
the inside and the outside part hidden under the trim are a 3m sealer. i'll have to look at the tube tonight for exact name and part number. we taped the lines and used a finger ( w/ rubber glove) to smooth out the bead. let it tack then pulled the tape.
the outside part of the b piller is mud.... rage gold to be exact.
Re: 63 unibody
Thanks that helps a bunch . I can get 3M products from my supplier as well as the rage gold mud .
noley99
Re: 63 unibody
Post by noley99 »
Impressive still Chris!
I'm jealous of the Plasma Cutter!
Family First!
Mrsinister
Re: 63 unibody
Post by Mrsinister »
Loving this truck
dragginwagon
Re: 63 unibody
thanx guys. havent touched her (other than blocking her down for final sealer), bought a new driver and getting it ready for paint. needed a 2nd family hauler and this was a good deal that the wife approved of :)
once its back from the paint shop ill get back on my unibody along with a few side jobs that are coming in this winter
couple pics of the "new" ride.
2003 supercrew, 65k miles bagged on 22s.
lincoln frontend is gone and putting a stock frontend back on and repainting the truck the stock color and getting black 22s
couple weeks ago when i bought her
yesterday, new frontend is in sealer and mockin everything up for paint
dragginwagon
Re: 63 unibody
noley99 wrote:Impressive still Chris!
funny you say that... less than a week after he stripped it, it blew up! and i do mean blew up...explosion and smoke!
1965fordf100
Re: 63 unibody
Post by 1965fordf100 »
Nice crew cab...I kinda like that Lincoln front end, obviously you weren't fond of it
Phil
dragginwagon
Re: 63 unibody
thanx, i was indifferent on the frontend.... but i got the truck knowing the front end needed love, the conversion fenders were cracking and pretty wavy ( fiber glass) they took a decent picture but in person werent all that great.
i was able to pick up everything to swap it back stock for lil over 200 bux so i felt like that was the "easier" route and instead of blending the paint we're just gunna reshoot the whole truck. has a few blems here and there from driving and all.
dragginwagon
Re: 63 unibody
super crew has been done for a while now... havent posted in a while
unibody is on the back burner again....once i finish this side job i'll be back on it, hopefully no more distractions till she's running and interior painted.
ezernut9mm
Sweden
Re: 63 unibody
Post by ezernut9mm »
i like that "true blue".
longcabjohn
Re: 63 unibody
Post by longcabjohn »
How did the hood project turn out?
Johnny
dragginwagon
Re: 63 unibody
on hold.... the guy flaked that was gunna orginally do it. ive got a new guy lined up just havent taken it to him
mercuryv8
Re: 63 unibody
Post by mercuryv8 »
How bout now?
LoL
Nic
