Slick4x4 rebuild of a farm truck
Well, I finally got the courage to post a build on here......
Drove my 'Blue Thunder into the shop this morning
This is what it looked like at 5 pm.... My mom (she's 87) asked me why I ripped up my truck
My plans ?
Out with the 223, in with 300 with headers & 4bbl intake & c6 auto trans
Dual brake master cylinder
Rebuild steering box
Refurbish interior
New wood in bed floor
New paint
Not going for car show quality.... Just make it a nice running farm truck to use
bobenhotep
Re: Slick4x4 rebuild of a farm truck
Post by bobenhotep »
The jump from the 223 to 300 was the best mod I have done to my truck so far.
My '63 short wrongbed
"The Iron Rhino"
-300-6 choke tube repair
-duraspark II/ HEI
-turn signal indicator fix
sgettin
Post by sgettin »
sounds like mom gets right to the point.
looking forward to your build thread keep the pictures coming.
kstones63
Post by kstones63 »
Pat,
Is your engine hoist heavy duty enough for that engine. :lol:
Kevin
kstones63
63 F100
29 Ford Sedan Delivery
99 F250 PSD, 4x4, CC
95 F350 Flatbed Dually Diesel
HiBoy63
Ireland
Post by HiBoy63 »
Looking forward to pics of your build. Your truck is a beast. I love it.
1963 F250 4x4x292
1965 F100 4x4x352
1998 F150 4x4x4.6
2001 Sport Track 4x4x4.0
Heritage country Flag
Hoofbeat Racer
Post by Hoofbeat Racer »
Good stuff Pat. I look forward to seeing your progress. Does this mean you will have his and hers pickups at Slickstock?
Mark
After a 2 year stop... I'm finally able to get in gear !
Hopefully get this on the road in 2016 !
I want to do everything I listed....
With the change to a 390 on propane instead of the 300 i6
You know Pat, I`ve never driven a Slick ....... is it going to have power steering and what colour are you going to paint it ? ...
Oh and back to my story, I have never driven a Slick in America, or one with left hand drive. I have ridden in a lot tho and it`s kind of weird ! :D
No power steering , as I rarely drive in town
Possible AC.... Sure be nice at times
Baby Blue.....
Not a common color, just going back to original
Lookin' good Pat, can't wait to see it at Slick Stock.
LM14
Post by LM14 »
Running it on propane, you could have a grille in the front and a grill in the bed.
Just a thought,
Rear leafs disassembled , cleaned , wiped with oil & put back together
Took out bottom 4 leafs
(They are straight & only used when you have a very heavy load)
I installed a 3" block wich gave me about 1 3/4" lift
I re-arched the fronts years ago & they are about 2" above stock
New u-bolts and shackle bushings also
Out with the bad.... In with the new
Using treated lumber... 1x6 boards
They measure 3/4" thick ( which is the same)
But only 5 1/2" wide (the original truck bed are 6")
But doesn't really matter, the tin rails cover the gap anyway
Wood , New bolts & washers.... Got it all at Lowes for $60
orangeRcode
Post by orangeRcode »
Liking the progress. Keep us updated!
Bed floor done ....
Rebuilding the bed I decided to "make it better than factory"
At least in my opinion....
Where the row of bolts that just had washers, I made a strap
Out of 1 1/2" by 3/16 ... and bolted it to the underside... Much
More support for just a small addition
Setting the 390 in...
Fabricated some engine mounts out of parts & pieces collected over years
Transmission mount needs fab too
Going to have to shorten the driveshaft between trans & transfer case
Seeing if things are gonna line up ...
Way to go Pat! Bet you will not have any trouble keeping up with the gang
on those road trips with that FE between the rails. Probably more like keeping
tires with tread on it now. HeeHee! :cheers: :steering: Keep up the good work!
Love the floor job on the bed too! TR
Crappy pic ... Cheap cell phone....
Layed down some paint....
Kinda rusty at it.... Had an issue with the fender :cussing:
Fixed it ...kinda.... I have to keep reminding myself ITS A FARM TRUCK
That looks a bit better....
Rattle can Ford blue.....
