fender to upper filler alignment
myoldman460
Post by myoldman460 »
Can someone post some pics of the way their fender meets with the filler panel under the hood. I think mine is bent or just not right.
therealjoeshmoe
Re: fender to upper filler alignment
Post by therealjoeshmoe »
i bet your front rubber cab mounts are bad and sagging..
Image Image Image Image
390fastback
Post by 390fastback »
Agreed, if your front mounts are gone, you'll have a wedge shaped gap at the cowl, and at the doors. The gap will be tight at the top and wide at the bottom. It would be pretty tough to bend that top filler peice.
plus many other's!
therealjoeshmoe
this what the gap should look like between the cowl and fender i just installed new bushings
skidoorulz
Post by skidoorulz »
I'm reading this as he wants pics of the front of the truck between grill and hood? Where the panel bolts to the fender?
myoldman460
skidoorulz, you are on it! The bottom edge of my filler dips down further than the fender. I'm not sure if this is the way it should be.
skidoorulz
Good picture toyz now I don't have to find mine
skidoorulz
Oh well what the heck. This is the best I got.
390fastback
Sorry, My missunderstanding! I can't show mine cause it doesn't line up worth a dam either!
plus many other's!
myoldman460
Thanks guys
ezernut9mm
Sweden
Post by ezernut9mm »
mine sucks as well. i have been jacking with the adjustments though. this is actually better than at first.
milldinaire
Post by milldinaire »
I moved my core support mounting hole forward 3/16 on the drivers side to line my fender and upper valace up. Worked like a charm.
