seat belts in slick crew
65 crewcab
Post by 65 crewcab »
how do you get the anchor point in between the doors with out cutting a major hole.or cutting the welds
1966 crewcab
Re: seat belts in slick crew
Have you got a photo we could look at 65 ?
65 crewcab
have to get one tomorrow then figure out how to post it
1966 crewcab
FarmMotorSports
Post by FarmMotorSports »
Can it be lowered from the headliner area in to position?
61 F250 Unibody
& 4WD
65 crewcab
That is closed in solid on the top can come in above the head liner in the back seat. was not wanting to drill out the pop rivets. But might be only way
the wall between the doors http://s1175.photobucket.com/user/65cre ... r.jpg.html
http://s1175.photobucket.com/user/65cre ... a.jpg.html
_
http://s1175.photobucket.com/user/65cre ... 4.jpg.html
could not get to post pics but could links
1966 crewcab
here you go 65, might need something a bit more sturdy than those pop rivets tho
65 crewcab
Thanks Allen. It is welded on the back side of the panel. I would be happy with just a lap belt but wife wants shoulder belts.
1966 crewcab
PFM-64f100
Post by PFM-64f100 »
This is how I did mine. Drilled a hole in the flat plate then welded a nut onto the back of it. Then I used some pop rivets to hold it on there. Not the best but figured it would slow me down for now.
I do have plans on redoing it by making a horizontal cut in the middle (location behind the current plate) then sliding the plate inside then reattaching the plate with the current pop rivets holes. This way it will be pulling on the complete panel and not just the rivets.
Wish I had more photos but looks like they got lost with the HD crash a while back. Dang HDs. :)
65 crewcab
Thanks for the reply and pics PFM. Was thinking of drilling the rivets out to gain access. Then putting them back in then adding a weld between each rivet.
1966 crewcab
orangeRcode
Post by orangeRcode »
PFM-64f100 wrote:This is how I did mine. Drilled a hole in the flat plate then welded a nut onto the back of it. Then I used some pop rivets to hold it on there. Not the best but figured it would slow me down for now.
Where did you source the seat belts?
PFM-64f100
Some place in Oklahoma I think. seat belts plus maybe. It has been a number of years sorry.
65 crewcab
Did a search for shoulder belts
1966 crewcab
